A few weeks ago I tried to connect my Yeelight (ylxd41yl) but without success. I removed yeelight config from configuration.yaml but I see in logs that HA it’s stil trying to connect with lamp.
How I can clear this from logs:
Logger: homeassistant.components.yeelight.config_flow
Source: components/yeelight/config_flow.py:231
Integration: Yeelight ([documentation](https://www.home-assistant.io/integrations/yeelight), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+yeelight%22))
First occurred: 2 października 2021, 23:35:20 (807 occurrences)
Last logged: 4 października 2021, 15:29:41
Failed to get properties from 192.168.8.50: Failed to read from the socket.
