HA is stuck in Legacy UI
I am trying to work on fixing iOS app notification errors in my HA but I don’t have access to Services in Dev tools.
I am fully updated
## System Information
version | core-2025.6.1
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.13.3
os_name | Linux
os_version | 6.6.74-haos-raspi
arch | aarch64
timezone | America/Chicago
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
HACS Data | ok
GitHub API Calls Remaining | 4993
Installed Version | 2.0.5
Stage | running
Available Repositories | 2099
Downloaded Repositories | 6
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | true
subscription_expiration | June 14, 2026 at 7:00 PM
relayer_connected | true
relayer_region | us-east-1
remote_enabled | true
remote_connected | true
alexa_enabled | true
google_enabled | true
cloud_ice_servers_enabled | true
remote_server | us-east-1-11.ui.nabu.casa
certificate_status | ready
instance_id | 3be52ba4adaa4383819cde804d25fd7c
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 15.2
update_channel | stable
supervisor_version | supervisor-2025.05.5
agent_version | 1.7.2
docker_version | 28.0.4
disk_total | 57.8 GB
disk_used | 20.6 GB
healthy | true
supported | true
host_connectivity | true
supervisor_connectivity | true
ntp_synchronized | true
virtualization |
board | rpi4-64
supervisor_api | ok
version_api | ok
installed_addons | Let's Encrypt (5.4.9), File editor (5.8.0), Samba share (12.5.1), Grafana (11.0.0), Studio Code Server (5.19.3), Log Viewer (0.17.1), ESPHome Device Builder (2025.6.0), Mosquitto broker (6.5.1), Samba Backup (5.2.0), Terminal & SSH (9.17.0)
</details>
<details><summary>Dashboards</summary>
dashboards | 3
resources | 4
views | 5
mode | storage
</details>
<details><summary>Network Configuration</summary>
adapters | lo (disabled), end0 (enabled, default, auto), hassio (disabled), docker0 (disabled), vethceb7c7b (disabled), veth414edc4 (disabled), vethfe2a1e5 (disabled), veth6a38d75 (disabled), veth62244cf (disabled), vethc1f5a3e (disabled), veth5247cd5 (disabled), veth7abc969 (disabled), veth74d62bc (disabled)
ipv4_addresses | lo (127.0.0.1/8), end0 (192.168.2.252/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), vethceb7c7b (), veth414edc4 (), vethfe2a1e5 (), veth6a38d75 (), veth62244cf (), vethc1f5a3e (), veth5247cd5 (), veth7abc969 (), veth74d62bc ()
ipv6_addresses | lo (::1/128), end0 (fe80::1da1:6ac7:1b06:1014/64), hassio (fe80::6:a0ff:fe14:df6e/64), docker0 (fe80::49b:e0ff:fea4:ff6e/64), vethceb7c7b (fe80::1878:c3ff:fefd:4245/64), veth414edc4 (fe80::28e2:9dff:fe9d:33c5/64), vethfe2a1e5 (fe80::bcf6:a9ff:fe95:b45b/64), veth6a38d75 (fe80::ac01:e5ff:fe4f:57ea/64), veth62244cf (fe80::2494:72ff:feb8:2840/64), vethc1f5a3e (fe80::60e9:eff:fe13:7ff5/64), veth5247cd5 (fe80::d4a1:8aff:fe46:f48f/64), veth7abc969 (fe80::1005:ceff:fe88:5e79/64), veth74d62bc (fe80::ec4b:78ff:fecf:3ec7/64)
announce_addresses | 192.168.2.252, fe80::1da1:6ac7:1b06:1014
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | November 14, 2024 at 2:17 AM
current_recorder_run | June 19, 2025 at 10:15 PM
estimated_db_size | 2813.41 MiB
database_engine | sqlite
database_version | 3.48.0
</details>
I for the life of me cannot get a way to switch to Modern UI. My iOS alerts stopped working with this error
and as I tried to investigate this previously working automation, I have gone down a rabbit hole with ChatGPT trying to get to the services configurations to try to fix the errors
Has anyoine else been battling the legacy/moder UI issue that may suggestion a new hole to go down?
FYI Running hassio on rpi4
It is called “Actions” now.
You have confused yourself further because the LLM knows nothing about recent developments. HA moves too fast for its training. Stop using it and read the documentation and ask questions here instead. You will get more sensible and meaningful answers.
Share your automation. The action appears correct, i.e. like this:
action: notify.mobile_app_ipad_pro
  message: test
  title: This is the title
So more likely the notify action name has changed. Look in Developer Tools → States for notify.mobile_app_...
Here is my alert setup:
alias: RefrigeratorFreezerAlert
description: RefrigeratorFreezerAlert
mode: single
triggers:
  - entity_id:
      - sensor.inside_refrigerator_temp_hum_c227_temperature
    for:
      hours: 0
      minutes: 0
      seconds: 0
    above: 41
    trigger: numeric_state
  - entity_id:
      - sensor.inside_freezer_temp_hum_4b8c_temperature
    above: 5
    for:
      hours: 0
      minutes: 0
      seconds: 0
  - entity_id:
      - sensor.garage_fridge_temp_hum_7b04_temperature
    for:
      hours: 0
      minutes: 0
      seconds: 0
    above: 41
  - entity_id:
      - sensor.garage_freezer_temp_hum_8e26_temperature
    for:
      hours: 0
      minutes: 0
      seconds: 0
    above: 10
  - entity_id:
      - sensor.chest_freezer_temp_hum_5045_temperature
    for:
      hours: 0
      minutes: 0
      seconds: 0
    above: -10
conditions: []
actions:
  - data:
      title: Refrigerator/Freezer Alert
      message: >-
        The {{ trigger.to_state.name }} is warm. Current temperature:{{
        trigger.to_state.state }}°F.
    action: notify.mobile_app_thedarknet
That should have been Developer Tools → Actions.
Does it exist?
Your format is off if that device exists. Take a look at Tom’s previous posted example
actions:
  - action: notify.mobile_app_thedarknet
      message: >-
        blah, blah , blah
How so?
This will work?
Yes. The order of the options in a dictionary is not important.
actions:
  - data:
is the same as:
actions:
  - action:
Thanks for clarifying. I did not know that! I never cam across the reverse format in the Docs, but I could have missed it. Always learning…
actions:
  - data:
Thanks @tom_l I found the requisite notification (notify.mobile_app_the_darknet). The notification still is not working
But this is something I should be able to figure out myself. I think this may be related to setting new tokens for the mobile app
Ok so you were missing an underscore in the entity id.
As for the new error:
Did you trigger the automation manually?
If you do that it skips the triggers and there will be no to_state trigger variable.
Change one of the temperature values in Developer Tools → States to trigger the automation. It is not permanent and you can set it back to what it was after the test or wait until the next sensor update.
I ended up just taking on of the temp sensors out of the fridge. The alert started working.
I ended up changing the automation to this
triggers:
  - entity_id:
    for:
      hours: 0
      minutes: 0
      seconds: 0
    above: 41
  - entity_id:
    above: 5
    for:
      hours: 0
      minutes: 0
      seconds: 0
  - entity_id:
    for:
      hours: 0
      minutes: 0
      seconds: 0
    above: 41
  - entity_id:
    for:
      hours: 0
      minutes: 0
      seconds: 0
    above: 10
  - entity_id:
    for:
      hours: 0
      minutes: 0
      seconds: 0
    above: -10
conditions: []
actions:
  - action: notify.allphoneapps
      message: >-
mode: single
An update my notification groups in configuration.yaml
notify:
  - platform: group
    services:
      - service: mobile_app_peaches99
      - service: mobile_app_the_darknet
I need to validate that thuis is working on my wife’s phone when she get’s home from work
I appreciate the feed back in the AI tools, but HomeAssistant is a deep well of possibilities and I have found that AI tools should be considered.
