Hey,
Since a few days ago i have noticed that my hass.io instance seems to hang and stall and at times doesn’t open up the front end. I think its a connection problem or an internet issue but can’t be sure.
I have clean installed my instance on a brand new image and then restored from backup but the issue still persists. I thought it might be a internet/ISP issue but i don’t have any other issues with devices on my home network.
I have attached my logs so someone with some technical ability can maybe identify what the issues is. I also set up a ping binary sensor to poll google DNS every 5 seconds and i have a picture of the average ping times below but dont have the know-how to tell if it means anything or not.
Set up
Hassio - Pi4 4GB
System: HassOS 3.5 (armv7 / raspberrypi4)
Home Assistant version: 0.99.3
Supervisor version: 189
connected through ethernet directly to router.
Logs
2019-10-09 07:52:02 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for zigbee2mqtt_networkmap which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-10-09 07:52:02 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for audiconnect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-10-09 07:52:02 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-10-09 07:52:02 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-10-09 07:53:10 ERROR (MainThread) [custom_components.audiconnect.audi_connect_account] API error: {'errorCode': 'gw.error.timeout', 'description': 'Backend Connection Timeout'}
2019-10-09 07:53:14 WARNING (MainThread) [homeassistant.setup] Setup of person is taking over 10 seconds.
2019-10-09 07:53:14 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2019-10-09 07:53:14 WARNING (MainThread) [homeassistant.setup] Setup of group is taking over 10 seconds.
2019-10-09 07:53:14 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2019-10-09 07:53:16 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for rpi_power which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-10-09 07:53:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for xboxone which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-10-09 07:53:42 WARNING (MainThread) [homeassistant.components.switch] Setup of platform alexa_media is taking over 10 seconds.
2019-10-09 07:53:42 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform alexa_media is taking over 10 seconds.
2019-10-09 07:54:00 ERROR (MainThread) [hacs.repository.integration.danobot.entity-controller] Missing manifest file.
2019-10-09 07:54:00 ERROR (MainThread) [hacs] Validation for danobot/entity-controller failed.
2019-10-09 07:55:23 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.google_dns is taking over 10 seconds
2019-10-09 07:55:23 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ping binary_sensor took longer than the scheduled update interval 0:00:05
2019-10-09 07:57:28 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ping binary_sensor took longer than the scheduled update interval 0:00:05
2019-10-09 07:58:35 ERROR (MainThread) [aiohttp.server] Error handling request
This file has been truncated. show original
Eeeeeediot
(Eeeeeediot)
October 10, 2019, 7:51pm
2
can any1 solve the mystery?
Eeeeeediot
(Eeeeeediot)
October 11, 2019, 6:19pm
3
I realised that my Hassio was stable before I switched to my new SD card and I forgot that when I did that I moved from the RPi4 64 bit to the 32bit version and that’s when my problems started!!
Either that or the new SD card was corrupted from the get go but I doubt it
