Hi
Since few days mon HA installation keeps on crashing / rebooting I’m unable to find the reason.
I’ve disabled / removed the recent integration app from HACS that I’ve added thinking that they were the reason but I still cannot resolve the issue.
I also added recently SkyConnect and the issue started, however I’m not sure it start immediately after because I configured it few hours later I’m not sure it’s the reason. It’s now unplugged.
Here is the details of my installation
Home Assistant 2023.7.3
Supervisor 2023.07.1
Operating System 10.3
Frontend 20230705.1 - latest
Raspberry Pi 3
and my logs:
File "/usr/src/supervisor/supervisor/store/repository.py", line 108, in update
await self.git.pull()
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 116, in wrapper
raise self.on_condition(error_msg, _LOGGER.warning) from None
supervisor.exceptions.StoreJobError: 'GitRepo.pull' blocked from execution, no supervisor internet connection
e[31m23-07-30 23:15:16 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-47833' coro=<Repository.update() done, defined at /usr/src/supervisor/supervisor/store/repository.py:104> exception=StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")>e[0m
future: <Task finished name='Task-47832' coro=<Repository.update() done, defined at /usr/src/supervisor/supervisor/store/repository.py:104> exception=StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")>e[0m
future: <Task finished name='Task-47831' coro=<Repository.update() done, defined at /usr/src/supervisor/supervisor/store/repository.py:104> exception=StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")>e[0m
e[31m23-07-30 23:17:23 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config: e[0m
e[33m23-07-30 23:17:24 WARNING (MainThread) [supervisor.misc.tasks] Watchdog miss API response from Home Assistante[0m
e[32m23-07-30 23:22:30 INFO (SyncWorker_5) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6e[0m
e[31m23-07-30 23:28:24 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config: e[0m
e[31m23-07-30 23:28:25 ERROR (MainThread) [supervisor.misc.tasks] Watchdog found a problem with Home Assistant API!e[0m
e[32m23-07-30 23:28:28 INFO (SyncWorker_4) [supervisor.docker.interface] Restarting ghcr.io/home-assistant/raspberrypi3-64-homeassistante[0m
e[32m23-07-30 23:32:23 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is readye[0m
e[32m23-07-30 23:32:52 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNINGe[0m
e[32m23-07-30 23:32:54 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m23-07-30 23:33:01 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/thomasmauerer/hassio-addons repositorye[0m
e[32m23-07-30 23:33:01 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/dshafik/haos-addons repositorye[0m
e[32m23-07-30 23:33:01 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repositorye[0m
e[32m23-07-30 23:33:01 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repositorye[0m
e[32m23-07-30 23:33:01 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repositorye[0m
e[32m23-07-30 23:33:01 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/alexbelgium/hassio-addons repositorye[0m
e[32m23-07-30 23:33:02 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.jsone[0m
e[32m23-07-30 23:33:18 INFO (MainThread) [supervisor.store] Loading add-ons from store: 154 all - 0 new - 0 removee[0m
e[32m23-07-30 23:38:34 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instancee[0m
e[31m23-07-30 23:39:00 ERROR (MainThread) [aiohttp.server] Error handling requeste[0m
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 185, in block_bad_requests
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 201, in system_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 268, in token_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 280, in core_proxy
File "/usr/src/supervisor/supervisor/api/utils.py", line 62, in wrap_api
answer = await method(api, *args, **kwargs)
File "/usr/src/supervisor/supervisor/api/backups.py", line 118, in list
data_backups = self._list_backups()
File "/usr/src/supervisor/supervisor/api/backups.py", line 96, in _list_backups
return [
File "/usr/src/supervisor/supervisor/api/backups.py", line 102, in <listcomp>
ATTR_SIZE: backup.size,
File "/usr/src/supervisor/supervisor/backups/backup.py", line 165, in size
if not self.tarfile.is_file():
File "/usr/local/lib/python3.11/pathlib.py", line 1267, in is_file
return S_ISREG(self.stat().st_mode)
File "/usr/local/lib/python3.11/pathlib.py", line 1013, in stat
return os.stat(self, follow_symlinks=follow_symlinks)
OSError: [Errno 112] Host is down: '/data/mounts/backup/278f2bc2.tar'
e[32m23-07-30 23:43:09 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
Hoping someone can help me thanks!
