Power supply is good and storage is low. Will put logs in:
Error while unsubscribing push: Host 192.168.1.253:443: connection error: Cannot connect to host 192.168.1.253:8000 ssl:default [Connect call failed (‘192.168.1.253’, 8000)].
Host 192.168.1.241:443: unknown exception “Connector is closed.” occurred, traceback: Traceback (most recent call last): File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 1073, in _wrap_create_connection sock = await aiohappyeyeballs.start_connection( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/impl.py”, line 104, in start_connection raise first_exception File “/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/impl.py”, line 81, in start_connection sock = await _connect_sock( ^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/impl.py”, line 166, in _connect_sock await loop.sock_connect(sock, address) File “/usr/local/lib/python3.12/asyncio/selector_events.py”, line 641, in sock_connect return await fut ^^^^^^^^^ File “/usr/local/lib/python3.12/asyncio/selector_events.py”, line 681, in _sock_connect_cb raise OSError(err, f’Connect call failed {address}') OSError: [Errno 113] Connect call failed (‘192.168.1.241’, 443) The above exception was the direct cause of the following exception: Traceback (most recent call last): File “/usr/local/lib/python3.12/site-packages/reolink_aio/api.py”, line 4664, in send_chunk response = await self._aiohttp_session.get(url=self._url, params=param, allow_redirects=False) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.12/site-packages/aiohttp/client.py”, line 657, in _request conn = await self._connector.connect( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 564, in connect proto = await self._create_connection(req, traces, timeout) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 975, in _create_connection _, proto = await self._create_direct_connection(req, traces, timeout) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 1350, in _create_direct_connection raise last_exc File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 1319, in _create_direct_connection transp, proto = await self._wrap_create_connection( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 1088, in _wrap_create_connection raise client_error(req.connection_key, exc) from exc aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host 192.168.1.241:443 ssl:default [Connect call failed (‘192.168.1.241’, 443)] During handling of the above exception, another exception occurred: Traceback (most recent call last): File “/usr/local/lib/python3.12/site-packages/reolink_aio/api.py”, line 4680, in send_chunk response = await self._aiohttp_session.post(url=self._url, json=body, params=param, allow_redirects=False) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.12/site-packages/aiohttp/client.py”, line 657, in _request conn = await self._connector.connect( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 567, in connect raise ClientConnectionError(“Connector is closed.”) aiohttp.client_exceptions.ClientConnectionError: Connector is closed.
Error from stream worker: Error demuxing stream (ERRORTYPE_110, Operation timed out, rtsp://:@192.168.1.241:554/Preview_01_sub)
Error from stream worker: Error opening stream (ERRORTYPE_110, Operation timed out, rtsp://:@192.168.1.241:554/Preview_01_sub)
Error from stream worker: Error opening stream (ERRORTYPE_113, Host is unreachable, rtsp://:@192.168.1.241:554/Preview_01_sub)
Timeout on /host/info request
Timeout on /store request
Timeout on /core/info request
Timeout on /supervisor/info request
Timeout on /os/info request
