HA keeps spinning after clicking Configure device
I run the latest version of HA. Updated all.
When I click “Configure”" on example ICSEE addon, the popup shows up that I have to wait a minute. But HA keeps showing spinning wheel and nothing happens. This also happens when trying to use the configure button on the robovac add-on. The only way to stop this is remove the power from the RPI and reboot the machine.
Does anyone has advise how to resolve this behaver. I cannot configure anything now.
Ha is working perfect aslong as I do not click “configere” on an add-on/device.
Please help
Extract the homeassistant.log.1 from the config directory and read it with a text editor.
Also post your hardware setup.
This is the content of the log I find under “Settings - System -Logs” :slight_smile:
This is the content of the homeassistant.log.1 after I cleaned it and restarted the system :slight_smile:
2024-12-10 12:16:28.910 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-12-10 12:16:28.915 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration robovac which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-12-10 12:16:28.921 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-12-10 12:16:33.481 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-12-10 12:16:33.659 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=69 from 2024-12-10 10:49:04.029462)
2024-12-10 12:17:08.115 WARNING (MainThread) [zigpy.config.validators] The `ikea_provider` key is deprecated, migrate your configuration to the `extra_providers` list instead: `extra_providers: [{'type': 'ikea'}]`
2024-12-10 12:17:08.115 WARNING (MainThread) [zigpy.config.validators] The `ledvance_provider` key is deprecated, migrate your configuration to the `extra_providers` list instead: `extra_providers: [{'type': 'ledvance'}]`
2024-12-10 12:17:08.116 WARNING (MainThread) [zigpy.config.validators] The `salus_provider` key is deprecated, migrate your configuration to the `extra_providers` list instead: `extra_providers: [{'type': 'salus'}]`
2024-12-10 12:17:08.116 WARNING (MainThread) [zigpy.config.validators] The `inovelli_provider` key is deprecated, migrate your configuration to the `extra_providers` list instead: `extra_providers: [{'type': 'inovelli'}]`
2024-12-10 12:17:08.116 WARNING (MainThread) [zigpy.config.validators] The `thirdreality_provider` key is deprecated, migrate your configuration to the `extra_providers` list instead: `extra_providers: [{'type': 'thirdreality'}]`
2024-12-10 12:17:09.931 WARNING (MainThread) [zigpy.config.validators] The `ikea_provider` key is deprecated, migrate your configuration to the `extra_providers` list instead: `extra_providers: [{'type': 'ikea'}]`
2024-12-10 12:17:09.931 WARNING (MainThread) [zigpy.config.validators] The `ledvance_provider` key is deprecated, migrate your configuration to the `extra_providers` list instead: `extra_providers: [{'type': 'ledvance'}]`
2024-12-10 12:17:09.932 WARNING (MainThread) [zigpy.config.validators] The `salus_provider` key is deprecated, migrate your configuration to the `extra_providers` list instead: `extra_providers: [{'type': 'salus'}]`
2024-12-10 12:17:09.932 WARNING (MainThread) [zigpy.config.validators] The `inovelli_provider` key is deprecated, migrate your configuration to the `extra_providers` list instead: `extra_providers: [{'type': 'inovelli'}]`
2024-12-10 12:17:09.932 WARNING (MainThread) [zigpy.config.validators] The `thirdreality_provider` key is deprecated, migrate your configuration to the `extra_providers` list instead: `extra_providers: [{'type': 'thirdreality'}]`
2024-12-10 12:18:36.334 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
  File "/usr/local/lib/python3.13/site-packages/onvif/managers.py", line 189, in _renew_or_restart_subscription
    await self._renew_subscription() or await self._restart_subscription()
  File "/usr/local/lib/python3.13/site-packages/onvif/managers.py", line 154, in _restart_subscription
    return await self._start()
  File "/usr/local/lib/python3.13/site-packages/onvif/managers.py", line 256, in _start
    result = await self._subscription.Renew(
        device.get_next_termination_time(self._interval)
  File "/usr/local/lib/python3.13/site-packages/zeep/proxy.py", line 64, in __call__
    return await self._proxy._binding.send_async(
    ...<5 lines>...
  File "/usr/local/lib/python3.13/site-packages/zeep/wsdl/bindings/soap.py", line 164, in send_async
    return self.process_reply(client, operation_obj, response)
  File "/usr/local/lib/python3.13/site-packages/zeep/wsdl/bindings/soap.py", line 229, in process_reply
    return self.process_error(doc, operation)
  File "/usr/local/lib/python3.13/site-packages/zeep/wsdl/bindings/soap.py", line 391, in process_error
    raise Fault(
    ...<5 lines>...
zeep.exceptions.Fault: ResourceUnknownFault
2024-12-10 12:26:50.661 WARNING (MainThread) [homeassistant.components.go2rtc.server] 12:26:50.660 WRN github.com/AlexxIT/go2rtc/internal/streams/producer.go:170 > error="read tcp 192.168.178.3:48110->3.78.237.40:443: i/o timeout" url=rtsps://echo:[email protected]:443/v1/bfa68ee0d3d1ab9192p5cd/ctc2at2io2f6jbhfqm8gr82HXOwW0xje?signInfo=VIGpDH8roZwx2eA3yTfpF5QKWvPFQG_OWHQo5aoJZRBdDbDXZQv_7qw7AhHZ5hoLw2784O5A-hJV-GVFA8OIStbPD1Xa3YshTl0Rzh4AEMogRK23EZMm6Et9L5krTl8GdW2p3cHh0eQs5mkUeGznpjqERi4AsptuTrJPiXdVKhU
The hardware is :
  • RPI4 / 4GB
  • Sonoff Zigbee USb Dongle-E
HACS integrations :
