HA Log error messages - need help
Hi, I need a helping hand to analyze this huge amount of error massages in HA log. For me it seemed to be an issue with zigbee integration (Sonoff Zigbee 3.0 USB, Zigbee Home Intergration).
2022-12-27 12:55:09.606 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration reolink_dev which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-27 12:55:09.619 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-27 12:55:09.621 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration sonnenbatterie which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-27 12:55:28.152 ERROR (Thread-2 (watcher)) [custom_components.sonnenbatterie] Failing sensor: sensor.sonnenbatterie_137636
2022-12-27 12:55:35.168 WARNING (MainThread) [homeassistant.setup] Setup of script is taking over 10 seconds.
2022-12-27 12:55:35.170 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform sonnenbatterie is taking over 10 seconds.
2022-12-27 12:56:06.194 WARNING (MainThread) [zigpy_znp.api] Failed to parse broken GeneralFrame(header=CommandHeader(id=0x9F, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x8B\x7C\x84\x09\x4C') as <class 'zigpy_znp.types.commands.ZDO.ParentAnnceRsp.Callback'>
2022-12-27 12:56:06.239 WARNING (MainThread) [zigpy_znp.api] Failed to parse broken GeneralFrame(header=CommandHeader(id=0x9F, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\xAD\xF3\x84\x09\x4C') as <class 'zigpy_znp.types.commands.ZDO.ParentAnnceRsp.Callback'>
2022-12-27 12:56:06.242 WARNING (MainThread) [zigpy_znp.api] Failed to parse broken GeneralFrame(header=CommandHeader(id=0x9F, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x65\x53\x84\x09\x4C') as <class 'zigpy_znp.types.commands.ZDO.ParentAnnceRsp.Callback'>
2022-12-27 12:56:06.246 WARNING (MainThread) [zigpy_znp.api] Failed to parse broken GeneralFrame(header=CommandHeader(id=0x9F, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\xDC\xEF\x84\x09\x4C') as <class 'zigpy_znp.types.commands.ZDO.ParentAnnceRsp.Callback'>
2022-12-27 12:56:06.254 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to deserialize ZDO packet
  File "/usr/local/lib/python3.10/site-packages/zigpy_znp/zigbee/application.py", line 485, in on_zdo_message
    zdo_hdr, zdo_args = self._device.zdo.deserialize(
  File "/usr/local/lib/python3.10/site-packages/zigpy/zdo/__init__.py", line 44, in deserialize
    args, data = t.deserialize(data, param_types)
  File "/usr/local/lib/python3.10/site-packages/zigpy/types/__init__.py", line 9, in deserialize
    value, data = type_.deserialize(data)
  File "/usr/local/lib/python3.10/site-packages/zigpy/types/basic.py", line 716, in deserialize
    item, data = cls._item_type.deserialize(data)
  File "/usr/local/lib/python3.10/site-packages/zigpy/types/basic.py", line 742, in deserialize
  File "/usr/local/lib/python3.10/site-packages/zigpy/types/basic.py", line 184, in deserialize
    raise ValueError(f"Data is too short to contain {byte_size} bytes")
ValueError: Data is too short to contain 1 bytes
2022-12-27 12:56:06.277 ERROR (MainThread) [zigpy.device] Failed to parse message (b'0384094c') on cluster 32799, because Data is too short to contain 1 bytes
2022-12-27 12:56:06.301 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to deserialize ZDO packet
2022-12-27 12:56:06.306 ERROR (MainThread) [zigpy.device] Failed to parse message (b'0384094c') on cluster 32799, because Data is too short to contain 1 bytes
2022-12-27 12:56:06.309 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to deserialize ZDO packet
2022-12-27 12:56:06.314 ERROR (MainThread) [zigpy.device] Failed to parse message (b'0384094c') on cluster 32799, because Data is too short to contain 1 bytes
2022-12-27 12:56:06.317 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to deserialize ZDO packet
2022-12-27 12:56:06.319 ERROR (MainThread) [zigpy.device] Failed to parse message (b'0384094c') on cluster 32799, because Data is too short to contain 1 bytes
2022-12-27 12:56:25.035 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x0CE3:3:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2022-12-27 12:56:25.083 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x0CE3:3:0x0300]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2022-12-27 12:56:25.706 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x54CE:1:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>')]
2022-12-27 12:56:25.736 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x54CE:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>')]
2022-12-27 12:56:25.798 WARNING (MainThread) [zigpy_znp.api] Failed to parse broken GeneralFrame(header=CommandHeader(id=0x9F, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x59\x9D\x84\x05\x0B') as <class 'zigpy_znp.types.commands.ZDO.ParentAnnceRsp.Callback'>
2022-12-27 12:56:25.802 WARNING (MainThread) [zigpy_znp.api] Failed to parse broken GeneralFrame(header=CommandHeader(id=0x9F, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x8B\x7C\x84\x05\x0B') as <class 'zigpy_znp.types.commands.ZDO.ParentAnnceRsp.Callback'>
2022-12-27 12:56:25.806 WARNING (MainThread) [zigpy_znp.api] Failed to parse broken GeneralFrame(header=CommandHeader(id=0x9F, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\xAD\xF3\x84\x05\x0B') as <class 'zigpy_znp.types.commands.ZDO.ParentAnnceRsp.Callback'>
2022-12-27 12:56:25.809 WARNING (MainThread) [zigpy_znp.api] Failed to parse broken GeneralFrame(header=CommandHeader(id=0x9F, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x65\x53\x84\x05\x0B') as <class 'zigpy_znp.types.commands.ZDO.ParentAnnceRsp.Callback'>
2022-12-27 12:56:25.814 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to deserialize ZDO packet
2022-12-27 12:56:25.817 ERROR (MainThread) [zigpy.device] Failed to parse message (b'0484050b') on cluster 32799, because Data is too short to contain 1 bytes
2022-12-27 12:56:25.819 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to deserialize ZDO packet
2022-12-27 12:56:25.822 ERROR (MainThread) [zigpy.device] Failed to parse message (b'0484050b') on cluster 32799, because Data is too short to contain 1 bytes
2022-12-27 12:56:25.824 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to deserialize ZDO packet
2022-12-27 12:56:25.827 ERROR (MainThread) [zigpy.device] Failed to parse message (b'0484050b') on cluster 32799, because Data is too short to contain 1 bytes
2022-12-27 12:56:25.829 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to deserialize ZDO packet
2022-12-27 12:56:25.832 ERROR (MainThread) [zigpy.device] Failed to parse message (b'0484050b') on cluster 32799, because Data is too short to contain 1 bytes
2022-12-27 12:56:26.966 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x0CE3:3:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2022-12-27 12:56:28.950 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1FB8:3:0x0300]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2022-12-27 12:56:28.961 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1FB8:3:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2022-12-27 12:56:31.087 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x54CE:1:0x0300]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>')]
2022-12-27 12:56:31.987 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1FB8:3:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
Hi, could someone please support me?
Peter
