HA loses static IP address
I have installed HAOS (9.5) on x86-64 platform with static IP address. Everything works fine unless I disconnect network cable. HA looses IP address even it is configured as static. ha network info doesn’t display IP address. When I plug the cable everything works fine again and ha network info shows correct static address.
My issue is that I need the IP adress even the network cable is diconntected (e.g. network router is not accessible for some time).
How to achieve not to loose the IP address in the case the network cable is not plugged in.
Any advice?
many thanks
It’s “lose” not “loose”.
When the network cable is unplugged, what do you need the static IP address for?
If you want to reference the HA from inside HA, you can always use the loopback address “localhost” or “127.0.0.1”. This will always point to the machine itself and works the same on any computer.
Unfortunately knxd addon terminates. And KNX integration looses connection to KNX bus despite the bus is connected viac USB interface. As the KNX integration works only with IP Routing/Tunnelling to KNX bus, I need to establish this endpoint uxing knxd addon. But when I disconnect the network, IP adress is gone and knxd stops.
Are you using Wifi or a cable connection? If only cable, it is normal to lose the IP address.
This knxd addon is running on the same machine? Did you try using the loopback IP 127.0.0.1?
What about using the “watchdog” feature? Go to settings → Add-on → select the add-on → Set watchdog on. That will restart the add-on if it stops.
I am on cable. I tried loopback, but the result was the same. Watchdog feature is on, so the addon tries to connect.
Technically I want to achieve setup where I have only HA box with USB interface to connect to KNX. Automations do not need front-end. Sure those devices which are in IP world on the network are not accessible without IP connectivity. Frontend as well. But if knx is connected via USB, it should work. Unfortunately KNX integration is working only with KNX IP router, but knxd is stopping when the HA box looses IP address.
Your router not being accessible is not the same as a disconnected cable.
A network interface without a cable is marked as down and therefore it cannot have an IP address.
So if you’d place a switch between HA and your router, it will remain connected, and keep its IP.
Theoretically a loopback adapter would also work…(note that it is not the same as a loopback address), but since you run a supervised OS, i don’t think you could use that
Yes, it is practically network without interface as the network component connected to it is OFF.
It is intended to be switched off. Then the only way is to wait until the USB KNX interface is developed.
It is funny because my old environment worked in this scenario (centos 6.5). But may be it was an implementation of eibd adapter to KNX network. Unfortunately eibd is no more supported and knxd looks to work slightly different.
Maybe you’ll have more luck with Calimero instead of knxd. There is an Addon for this too.
Why doesn’t using the loopback interface work?
I was not able to find Calimero Addon . Only knxd. Could you provide me with the link?
I don’t know how Add-on lookup works (have never used Home Assistant OS). Here is the repo if that helps: hassio-addons/calimero-server at bbee72a87a91980792655d49fa5e134cfee4fa85 · aschamberger/hassio-addons · GitHub
Imho the most reliable way to solve your problem is to change your USB interface for a KNX IP Interface and not use any of these Addons at all.
Calimero AddOn is only for ARM, but I have x86 architecture.
Did you try using the loopback address 127.0.0.1 ?
That is always reachable.
