I’m having an annoying issue with the Lifix integration in which some bulbs seem to drop off of HA. They still respond on the Lifix app but in order to recover them for HA, I need to restart Home Assistant. Power cycling the lights does not help.
Is there something in HA I could do to improve the stability of the HA connection? With HA Green, rebooting takes a significant amount of time.
I can’t even see RSSI values now. The Lifix app hides it and the Xfinity router doesn’t show it either. Lifix app shows them all to have a “strong” signal.
I used to have two independent 2.4 GHz APs for upstairs and downstairs. But it seemed the Lifix lights were having issues and dropping connections with two strong signals, even though the channels didn’t overlap, and the lights were only joined to one of them.
I still don’t understand why that was a problem, but it was suggested by Lifix support. Perhaps it has something to do with how WiFi IoT devices work?
The lights that occasionally drop from HA now are some of my oldest lights. So age might be the case.
I had another Lifix go offline from HA this morning. I verified it worked from the Lifix app and then left if be. It was working again by the time I got home.
Seems the issue might be something in HA since the WiFi connection is still good.
What did you mean about hold-off time between reloads? Is that something that can be modified?
I just had this issue start in the past week.
It has been rock solid for several years.
Like yours, it still works in the app and claims good connection.
I only have two bulbs.
The “LIFX Color 1000” is the one that has a problem
The “LIFX Mini Color” works fine.
edit:
D’oh, I read “January '24” for OP and thought, this is new… It’s 2025. sigh.
I had this problem I did a full reboot of home assistant and found it was Home Assistant scene I was using so I stop using scene’s with my lifx 4 bulbs now all work fine no freezing or lost connections.
Lost power 2 days ago, that one light lost it’s mind again and I’ve tried twice to reconnect it but the LIFX app isn’t working to get it back on the network.
I think they’ve sort of abandoned their early models.
Also with newer firmware/devices you have to wait about 10-15 minutes for the Homekit discovery to time out before the light will advertise its set up access point.
Yes, I did the 5x dance and on about the 12th try (over several days) it worked. But last time it only took about 5 tries. And maybe the first time before that.
From the router side it really is the device dropping off, the MAC address was just gone from the list.
I have a scene that turns the lights on and off during the day and the turning on works, but for the old one, it no longer turns off all the time. That has to be done manually 2 or 3 times a week.
Works
Firmware v3.90
Model: LIFX Mini C
Cloud connected (I’m unfamiliar with this setting)
Has problems
Firmware: v1.22 (it claims this is up to date)
Model: LIFX Color 1000
Not cloud connected (I’m unfamiliar with this setting)
I’d prefer neither connected to cloud.
Seeing the version numbers it may just be the price I pay for keeping old hardware.
