Hi
In order to start learning yaml configs and HA, I thought I would setup a simple MQTT broker / client scenario using the example configuration from the HA MQTT blog page: https://home-assistant.io/blog/2015/09/11/different-ways-to-use-mqtt-with-home-assistant/. This requires two additions to configuration.yaml, namely:
mqtt:
broker: 127.0.0.1
- platform: mqtt
state_topic: "home-assistant/fabian/mood"
After rebooting however, HA fails to start and I get a log entry of:
16-11-20 23:10:19 homeassistant.util.yaml: duplicate key: "sensor"
So, I changed ‘sensor’ to sensor2. HA now boots, but I get a log entry of:
'16-11-20 23:33:08 homeassistant.loader: Unable to find component sensor2'
searching for help and hints seems to confirm that the singular term ‘sensor’ should be correct.
Any advice to help me move on to the next point of failure???
Cheers!
Tom
