I was working on how to integrate Tasmota based Wifi IR Bridge but couldn’t find one. So I had to go through a lot of documentation. I want to help others and make the steps for MQTT HVAC integration simple with Tasmota based Wifi IR Bridge.
I hope my post helps others too.
Hello there, ive checked your post on YTF IR, did most of the steps you applied,
then tested to send commands through there and worked perfectly.
later on, added the configuration.yaml
after that added the node red code you provided and edited provides as you recommended.
at this picture below show me errors and don’t know how to fix them, unless there is on solution which is ignore all errors!
also, changed vendor and model to be like my AC.
in switch node, added (KELVINATOR) as my ac vendor.
unfornately the result was
So, i don’t know at which place i made mistake(s), could you please help me
to find a solution for that problem to get it works …
Appreciate your great Guidance!
i wish to add more pictures to make you see what’s going on, but unfortunately, I’m not allowed to add more than 3 pictures.
