I have been running my Home Assistant installation for more than a year and would now like to include my wallbox. To do this, I would like to use the
ha-multiscrape integration to read the current meter reading.
The configuration for this is as follows:
multiscrape:
- name: Wallbox
resource: https://192.168.2.36/cgi_s_ldp1.session
scan_interval: 60
verify_ssl: false
form_submit:
submit_once: True
input:
username: admin
password: "I will not publish that here ;)"
- unique_id: Zaehlerstand
name: Wallbox Zählerstand
select: "body > div.sheet > div.main > div:nth-child(2) > table > tbody > tr:nth-child(20) > td:nth-child(2)"
2024-02-09 10:50:28.130 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Wallbox # New run: start (re)loading data from resource
2024-02-09 10:50:28.130 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Wallbox # Rendered resource template into: https://192.168.2.36/cgi_s_ldp1.session
2024-02-09 10:50:28.130 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Starting with form-submit
2024-02-09 10:50:28.130 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Skip scraping form, assuming all input is given in config.
2024-02-09 10:50:28.130 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Merged input fields with input data in config. Result: {'username': 'admin', 'password': 'I will not publish that here ;)'}
2024-02-09 10:50:28.131 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Determined the url to submit the form to: https://192.168.2.36/
2024-02-09 10:50:28.131 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Submitting the form
2024-02-09 10:50:28.131 DEBUG (MainThread) [custom_components.multiscrape.http] Wallbox # Executing form_submit-request with a POST to url: https://192.168.2.36/ with headers: {}
2024-02-09 10:50:28.219 DEBUG (MainThread) [custom_components.multiscrape.http] Wallbox # Response status code received: 200
2024-02-09 10:50:28.219 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Form seems to be submitted succesfully (to be sure, use log_response and check file). Now continuing to retrieve target page.
2024-02-09 10:50:28.219 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Wallbox # Request data from https://192.168.2.36/cgi_s_ldp1.session
2024-02-09 10:50:28.219 DEBUG (MainThread) [custom_components.multiscrape.http] Wallbox # Executing page-request with a get to url: https://192.168.2.36/cgi_s_ldp1.session with headers: {}
2024-02-09 10:50:28.238 DEBUG (MainThread) [custom_components.multiscrape.http] Wallbox # Response status code received: 200
2024-02-09 10:50:28.238 DEBUG (MainThread) [custom_components.multiscrape.scraper] Wallbox # Loading the content in BeautifulSoup.
2024-02-09 10:50:28.244 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Wallbox # Data succesfully refreshed. Sensors will now start scraping to update.
2024-02-09 10:50:28.244 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Finished fetching multiscrape data in 0.114 seconds (success: True)
2024-02-09 10:50:28.244 DEBUG (MainThread) [custom_components.multiscrape.sensor] Wallbox # Wallbox Zählerstand # Start scraping to update sensor
2024-02-09 10:50:28.245 DEBUG (MainThread) [custom_components.multiscrape.scraper] Wallbox # Wallbox Zählerstand # Tag selected: None
2024-02-09 10:50:28.245 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Exception occurred while scraping, will try to resubmit the form next interval.
2024-02-09 10:50:28.245 ERROR (MainThread) [custom_components.multiscrape.sensor] Wallbox # Wallbox Zählerstand # Unable to scrape data: Could not find a tag for given selector
Consider using debug logging and log_response for further investigation.
2024-02-09 10:50:28.245 DEBUG (MainThread) [custom_components.multiscrape.sensor] Wallbox # Wallbox Zählerstand # On-error, set value to None
2024-02-09 10:50:28.245 DEBUG (MainThread) [custom_components.multiscrape.entity] Wallbox # Wallbox Zählerstand # Sensor updated and state written to HA
Do you have any ideas on how I should adapt my selector? I don’t know what to do after I’ve been tinkering with it for 2 days now and have browsed through various forum entries.
There’s no tbody in that HTML. The DOM structure on the right-hand side of your screenshot is lying to you.
Also, there’s no need to be so specific. You’ll probably find that:
select: "tr:nth-child(20) > td:nth-child(2)"
will work. Just look at the HTML and work out how you’d describe the wanted element to someone: it’s the second cell (<td>) of the 20th row (<tr>).
thank you very much for your fast reply .
Unfortunately, the error persists even with your good advice.
2024-02-09 14:44:15.872 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Wallbox # New run: start (re)loading data from resource
2024-02-09 14:44:15.872 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Wallbox # Rendered resource template into: https://192.168.2.36/cgi_s_ldp1.session
2024-02-09 14:44:15.872 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Starting with form-submit
2024-02-09 14:44:15.872 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Skip scraping form, assuming all input is given in config.
2024-02-09 14:44:15.872 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Merged input fields with input data in config. Result: {'username': 'admin', 'password': 'xxxxxx'}
2024-02-09 14:44:15.873 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Determined the url to submit the form to: https://192.168.2.36/cgi_s_ldp1.session
2024-02-09 14:44:15.873 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Submitting the form
2024-02-09 14:44:15.873 DEBUG (MainThread) [custom_components.multiscrape.http] Wallbox # Executing form_submit-request with a POST to url: https://192.168.2.36/cgi_s_ldp1.session with headers: {}
2024-02-09 14:44:15.959 DEBUG (MainThread) [custom_components.multiscrape.http] Wallbox # Response status code received: 200
2024-02-09 14:44:15.959 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Form seems to be submitted succesfully (to be sure, use log_response and check file). Now continuing to retrieve target page.
2024-02-09 14:44:15.959 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Wallbox # Using response from form-submit as data. Now ready to be scraped by sensors.
2024-02-09 14:44:15.959 DEBUG (MainThread) [custom_components.multiscrape.scraper] Wallbox # Loading the content in BeautifulSoup.
2024-02-09 14:44:15.965 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Finished fetching multiscrape data in 0.093 seconds (success: True)
2024-02-09 14:44:15.965 DEBUG (MainThread) [custom_components.multiscrape.sensor] Wallbox # Wallbox Zählerstand # Start scraping to update sensor
2024-02-09 14:44:15.966 DEBUG (MainThread) [custom_components.multiscrape.scraper] Wallbox # Wallbox Zählerstand # Tag selected: None
2024-02-09 14:44:15.966 DEBUG (MainThread) [custom_components.multiscrape.form] Wallbox # Exception occurred while scraping, will try to resubmit the form next interval.
2024-02-09 14:44:15.966 ERROR (MainThread) [custom_components.multiscrape.sensor] Wallbox # Wallbox Zählerstand # Unable to scrape data: Could not find a tag for given selector
2024-02-09 14:44:15.966 DEBUG (MainThread) [custom_components.multiscrape.sensor] Wallbox # Wallbox Zählerstand # On-error, set value to None
2024-02-09 14:44:15.966 DEBUG (MainThread) [custom_components.multiscrape.entity] Wallbox # Wallbox Zählerstand # Sensor updated and state written to HA
Thank you for your approaches @Troon
Sometimes it’s helpful just to write to someone. I have just been able to solve the problem - it was probably a problem with the authentication.
Here are a few more keywords in case someone else has the same problem and would like to include their Compleo / Innogy Wallbox professional Pro in Home Assistant over the LAN connected webinterface.
