HA needs a lot of to start home Assistant
I created a sd with Raspberry Pi-Imager with HomeAsssitant for Pi4, added
overlay_prefix=slot-A/overlays/
to confif.txt and started with this sd.
In observer I see:
2024-12-14 13:21:38.051 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-multicast · GitHub with version 2024.03.0
2024-12-14 13:21:38.093 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
2024-12-14 13:21:39.019 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast Package aarch64-hassio-multicast · GitHub with version 2024.03.0 - Host
2024-12-14 13:21:39.022 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
2024-12-14 13:21:39.049 INFO (MainThread) [supervisor.docker.interface] No version found for Package raspberrypi4-64-homeassistant · GitHub
2024-12-14 13:21:39.049 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image Package raspberrypi4-64-homeassistant · GitHub found.
2024-12-14 13:21:39.065 INFO (MainThread) [supervisor.docker.interface] Attaching to Package raspberrypi4-64-homeassistant · GitHub with version landingpage
2024-12-14 13:21:39.065 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
2024-12-14 13:21:39.089 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
2024-12-14 13:21:39.143 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2024-12-14 13:21:40.189 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant
Now shows the clock 20:11.
Will this never end?
Thanks for any help
That means HA is up and running. Why don’t you log into the app? homeassiant.local:8123
