Good morning Everyone.
I love the idea of HA, but I can’t figure it out what is wrong with my configuration. I’ve got some devices connected with Homekit trough HA. When I’m home, connected to same Wi-Fi- everything work just fine. If I try to manage my home trough cellular data- sometimes I’m able to, but most times devices connected trough HA are unreachable. I’ve got one camera connected to homekit via official way, and it works fine in the same time. Can somebody help me with that?
My setup is:
Raspberry Pi 4 8gb RAM
HA installed on SSD drive, connected to USB
All connected to router via Ethernet cable
Some logs that should be useful:
OSError: [Errno 101] Network unreachable
2023-03-31 20:01:30.101 ERROR (SyncWorker_5) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:01:33.114 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=29 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=29, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 34344)>
2023-03-31 20:01:45.100 ERROR (SyncWorker_0) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:02:00.101 ERROR (SyncWorker_8) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:02:03.119 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=29 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=29, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 34344)>
2023-03-31 20:02:15.099 ERROR (SyncWorker_2) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:02:25.313 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=17 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=17, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 47976)>
2023-03-31 20:02:25.318 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=17 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=17, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 47976)>
2023-03-31 20:02:30.100 ERROR (SyncWorker_6) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:02:33.124 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=29 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=29, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 34344)>
2023-03-31 20:02:45.099 ERROR (SyncWorker_1) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:03:00.101 ERROR (SyncWorker_3) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:03:03.130 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=29 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=29, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 34344)>
2023-03-31 20:03:15.101 ERROR (SyncWorker_0) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:03:30.101 ERROR (SyncWorker_8) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:03:33.137 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=29 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=29, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 34344)>
2023-03-31 20:03:45.099 ERROR (SyncWorker_2) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:04:00.101 ERROR (SyncWorker_7) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:04:03.142 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=29 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=29, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 34344)>
2023-03-31 20:04:15.099 ERROR (SyncWorker_3) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:04:25.314 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=17 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=17, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 47976)>
2023-03-31 20:04:25.319 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=17 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=17, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 47976)>
2023-03-31 20:04:30.101 ERROR (SyncWorker_5) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:04:33.149 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=29 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=29, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 34344)>
2023-03-31 20:04:45.099 ERROR (SyncWorker_0) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:05:00.100 ERROR (SyncWorker_8) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:05:03.154 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=29 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=29, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 34344)>
2023-03-31 20:05:15.100 ERROR (SyncWorker_6) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:05:30.101 ERROR (SyncWorker_7) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:05:33.159 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=29 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=29, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 34344)>
2023-03-31 20:05:45.100 ERROR (SyncWorker_3) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:06:00.101 ERROR (SyncWorker_0) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:06:03.165 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=29 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=29, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 34344)>
2023-03-31 20:06:15.100 ERROR (SyncWorker_9) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:06:25.314 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=17 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=17, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 47976)>
2023-03-31 20:06:25.319 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=17 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=17, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 47976)>
2023-03-31 20:06:30.100 ERROR (SyncWorker_2) [miio.miioprotocol] failed to send msg: [Errno 101] Network unreachable
2023-03-31 20:06:31.631 ERROR (MainThread) [pyatv.protocols.airplay] Failed to set up remote control channel
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/airplay/__init__.py", line 258, in _connect_rc
await control.start(str(core.config.address), control_port, credentials)
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/airplay/remote_control.py", line 55, in start
self.connection = await http_connect(address, control_port)
File "/usr/local/lib/python3.10/site-packages/pyatv/support/http.py", line 558, in http_connect
_, connection = await loop.create_connection(HttpConnection, address, port)
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1076, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1060, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 969, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 501, in sock_connect
return await fut
File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 509, in _sock_connect
sock.connect(address)
2023-03-31 20:06:31.636 ERROR (MainThread) [homeassistant.components.apple_tv] Failed to connect
File "/usr/src/homeassistant/homeassistant/components/apple_tv/__init__.py", line 222, in connect_once
await self._connect(conf, raise_missing_credentials)
File "/usr/src/homeassistant/homeassistant/components/apple_tv/__init__.py", line 324, in _connect
self.atv = await connect(conf, self.hass.loop, session=session)
File "/usr/local/lib/python3.10/site-packages/pyatv/__init__.py", line 135, in connect
await atv.connect()
File "/usr/local/lib/python3.10/site-packages/pyatv/core/facade.py", line 575, in connect
if await setup_data.connect():
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/mrp/__init__.py", line 941, in _connect
await protocol.start()
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/mrp/protocol.py", line 129, in start
await self.connection.connect()
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/mrp/connection.py", line 104, in connect
await self.loop.create_connection(lambda: self, self.host, self.port)
raise exceptions[0]
return await fut
