Ha-ngx is a Mobile-First Front-End for Home Assistant that takes a functional approach to managing many buttons on a small display. Ha-ngx is built with angular 6 + Material and communicates to your HA instance using the websocket API.
User Flow
- When you first navigate to the app, you are met with a login that asks for your websocket URL and api_password and stores it in browser localStorage for future visits.
- You are then taken to a room specific control panel, that shows controls for only the devices in that room
- To change rooms, you tap the “Home” icon in the upper left corner, and a map of the house will slide into view, allowing you to select a different room.
- Once a different room is selected, you will see a new control panel for the new room
Implementation
- Angular Single-Page-Application for instant page navigation
- Angular Material for all the buttons, sliders, navigation, etc
- Communication to Home Assistant using the Websocket API for real-time updates
Progress so far:
- Light Component:
- Drag button down to set brightness
- Drag button up to turn off light
Here is the github of my project.
Thanks!
-Chuck
