HA no longer accessible
I run HA on virtualbox with Tailscale to access externally.
I tried to update the HA core and it had an issue and didn’t complete. I booted back in and it initially was accessible, but kept crashing shortly after boot. I always make a copy of the VDI file so I replaced the file with the backup vdi and rebooted. It goes into the shell, but I can no longer access the via the xxx.local:8123 or the tailscale url. The observer url is active and shows connected, supported and healthy.
Any logs I should check or things i should type into the shell?
It looks like my core is crashing. The logs has a KeyError: ‘users’ listed.
