HA not passing changes made in configurator, menu always shows red dots
For some reason in configurator my 3 dots menu stays red which is what indicators that I need to restart HASS after changes have been saved.
I have restarted 4 times, powered my raspberry off/on and even updated to newer version of HA.
The last change I made was in ui-lovelace.yaml (renamed switch) which the file saved the changes eg if I close and re-open the file my changes are there, but the changes do not come through on the love lace dashboard.
Any ideas?!
Screenshot_3|690x305
Have you saved the changes?
Yes changes are saved, well at least the saved button goes and when I close and re-open the yaml file it has the changes in it.
No, that’s not what the red dots indicate. They indicate that a newer version of the configurator is available. Unfortunately the hassio-addon (in the official repository) has still not been updated. Here’s the pending pull request: Update configurator to 0.3.4 by danielperna84 · Pull Request #448 · home-assistant/addons · GitHub
If you don’t want to wait for the official addon to be published you can add my external repository in the addon-store and install it from there: GitHub - danielperna84/hassio-addons: Repository for hass.io add ons
I do not know why the changes you make don’t become effective though. However, it’s definetely not related to the red dots.
I found why it not updating. Coz the latest update I did to Hassio stopped using my ui-lovelace.yaml file and started using the front end editor file.
