Ive got two of these thermostats. Ive got the high and low temps set in HA and the mode is heat/cool. However when HA is controlling it only does heat. When the temp rises above the high temp i set, its not switching to cool.
Is it HA or is it the thermostats? I can manually change the thermostats to auto, and on the screen it says auto change on.
What do you mean “when ha is controlling it”? All HA does is set the modes and temperature set points, it does not make the thermostat turn on/off each element.
The T6 is controlling the HVAC. If you put it in the desired modes using the T6 panel does it work? If it doesn’t it’s likely wired up incorrectly.
IIRC when I set my T6 up, I had to put it in a specific zwave mode to make it follow it’s own schedule. I also had to set a bunch of other things too. All covered in the manual.
I use the T6 and haven’t had to do anything other than a couple scripts to keep the temps from reporting erroneous values every once in a very long while. It was pretty much plug and play otherwise. I love it over the Nest it replaced.
