Hi Guys,
I tried fixing this a number of months ago but no luck, i am trying to create a thermostat card but it cant see any entity in the climate dir, have a look at the video below to explain a bit better, hope you can help.
Climate Entity Video - Click Here
thanks a mill
You skipped the part where you confirmed the YAML configuration configuration checked out OK in developer tools or showing the actual climate entity under Devices and Services.
Looks like your climate entity isn’t being created, likely due to a YAML error. Have you tried simplifying your YAML by removing the include and putting the minimal climate config?
Have you tried creating this entity via Helpers in the UI?
Does it show up as an entity? Can you look up the climate.temp_downstairs?
Do you get errors in the HA log on loading the configuration? You likely have to perform a restart of HA to implement the configuration.
that did it, thank you so much
