Hi!
I installed HA and mosquitto. According MQTT Brokers I modified following line in “[email protected]” file to
“After=network-online.target mosquitto.service”
to start HA after mosquitto. After reboot mosquitto starts but HA is inactive:
~$ sudo systemctl status home-assistant@homeassistant
● [email protected] - Home Assistant
Loaded: loaded (/etc/systemd/system/[email protected]; enabled; vendor preset: enabled)
Active: inactive (dead)
if I start service manually it starts fine
without mosquitto.service in “[email protected]” file :
“After=network-online.target”
both mosquitto and HA active after reboot
Could you please help with this issue?
PS: mosquitto.service is added using systemd:
~$ sudo systemctl status mosquitto.service
● mosquitto.service - Mosquitto MQTT Broker daemon
Loaded: loaded (/etc/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2018-11-21 13:57:37 +06; 38min ago
Main PID: 760 (mosquitto)
Tasks: 1 (limit: 2309)
CGroup: /system.slice/mosquitto.service
└─760 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf -d
Regards,
Doszhan
