Hi. I just did a hassio ha restart after making some changes and now Home Assistant is not starting up. I can ping the server, but the UI never becomes available, and I can’t ssh onto it. Has anyone got any idea what could have happened? I’m pretty sure that config changes couldn’t have made this happen.
Actually it 100% can make that happen. You need to look at the log file and see why it’s not starting, but my guess is that you have a syntax error on your config.
I had a block of yaml commented out, then just did Ctrl + / to uncomment, assuming that it would still be indented correctly. The block was 1 space out.
2019-08-09 21:28:56 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] while parsing a block collection
