I was able to get HA installed but I now can not boot into Raspian it only boots to the command line for HA. How do I reach the front of HA? What did I miss?
Installed how? There are 4 different installed methods for Pi (if you include HA Supervised). Which one did you use?
Correct. HA is a headless system, all you ever see on a screen is a terminal.
HA is managed using a browser from another computer. Connect to http://xx.xx.xx.xx:8123 where xx.xx.xx.xx is the IP-address of your Pi4 (or use http://homeassistant.local:8123 if mDns is working OK on your lan)
This is to be expected. You replaced the raspbian operating system with the home assistant operating system.
