I had Rhasspy Base and 2 Satellites working, then moved the HA server and a satellite to demonstrate … now the intents are not actioned
The satellite and Rhasspy on the base station seem to be working correctly (Home page on base station Rhasspy is showing the correct intent and JSON).
The satellite’s console includes:
[DEBUG:2021-12-06 16:49:53,739] rhasspyhomeassistant_hermes: <- NluIntent(input='turn on study light', intent=Intent(intent_name='LightState', confidence_score=1.0), site_id='sat-2', id=None, slots=[Slot(entity='state', value={'kind': 'Unknown', 'value': 'on'}, slot_name='state', raw_value='on', confidence=1.0, range=SlotRange(start=5, end=7, raw_start=5, raw_end=7)), Slot(entity='name', value={'kind': 'Unknown', 'value': 'study light'}, slot_name='name', raw_value='study light', confidence=1.0, range=SlotRange(start=8, end=19, raw_start=8, raw_end=19))], session_id='sat-2-porcupine_raspberry-pi-44b9366a-3c31-4ade-9689-51549472e015', custom_data='porcupine_raspberry-pi', asr_tokens=[[AsrToken(value='turn', confidence=1.0, range_start=0, range_end=4, time=None), AsrToken(value='on', confidence=1.0, range_start=5, range_end=7, time=None), AsrToken(value='study', confidence=1.0, range_start=8, range_end=13, time=None), AsrToken(value='light', confidence=1.0, range_start=14, range_end=19, time=None)]], asr_confidence=0.753947, raw_input='turn on study light', wakeword_id='porcupine_raspberry-pi', lang=None)
[DEBUG:2021-12-06 16:49:53,744] rhasspyserver_hermes: Sent 858 char(s) to websocket
[DEBUG:2021-12-06 16:49:53,757] rhasspyhomeassistant_hermes: http://192.168.1.98:8123/api/intent/handle
[ERROR:2021-12-06 16:49:53,806] rhasspyhomeassistant_hermes: handle_home_assistant_intent
File "/usr/lib/rhasspy/rhasspy-homeassistant-hermes/rhasspyhomeassistant_hermes/__init__.py", line 173, in handle_home_assistant_intent
response.raise_for_status()
File "/usr/lib/rhasspy/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 1005, in raise_for_status
headers=self.headers,
aiohttp.client_exceptions.ClientResponseError: 500, message='Internal Server Error', url=URL('http://192.168.1.98:8123/api/intent/handle')
[ERROR:2021-12-06 16:49:53,807] rhasspyhomeassistant_hermes: handle_intent
File "/usr/lib/rhasspy/rhasspy-homeassistant-hermes/rhasspyhomeassistant_hermes/__init__.py", line 88, in handle_intent
assert response_dict, f"No response from {self.url}"
AssertionError: No response from http://192.168.1.98:8123/
[DEBUG:2021-12-06 16:50:18,128] rhasspymicrophone_cli_hermes: <- AsrStopListening(site_id='sat-2', session_id='sat-2-porcupine_raspberry-pi-44b9366a-3c31-4ade-9689-51549472e015')
[DEBUG:2021-12-06 16:50:18,128] rhasspywake_porcupine_hermes: <- HotwordToggleOn(site_id='sat-2', reason=<HotwordToggleReason.DIALOGUE_SESSION: 'dialogueSession'>)
[DEBUG:2021-12-06 16:50:18,129] rhasspywake_porcupine_hermes: Enabled
indicating that HA is not processing the intent. To aid debugging, in my configuration.yaml I commented out the larger intents.yaml and instead inserted directly into HA’s configuration.yaml:
#intent: !include intents.yaml
intent:
LightState:
speech:
text: Turning {{ name }} {{state }}
- service: light.turn_{{ state }}
entity_id: light.{{ name | replace(" ","_") }}
In HA’s Log Viewer:
File "/usr/src/homeassistant/homeassistant/components/intent/__init__.py", line 69, in post
intent_result = await intent.async_handle(
File "/usr/src/homeassistant/homeassistant/helpers/intent.py", line 62, in async_handle
raise UnknownIntent(f"Unknown intent {intent_type}")
homeassistant.helpers.intent.UnknownIntent: Unknown intent LightState
In HA’s Configuration > Logs there is an “Error handling request” (also Supervisor > System > Core log) :
Logger: aiohttp.server
Source: helpers/intent.py:62
First occurred: 4:49:53 PM (1 occurrences)
Last logged: 4:49:53 PM
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 98, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 24, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 138, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 135, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 62, in wrapper
result = await method(view, request, *args, **kwargs)
I don’t see any obvious change or error.
Is there anything else can I try before taking a new card and installing HA again from scratch ??
