It has happened twice now, months apart, where according to logs in my Unifi instance, Home assistant has paused both firewall rules and wifi networks on my Unifi controller. At the same time, some of my Insteon devices, driven through a Universal Devices EISY, turn off. Also, within the EISY interface, many Insteon devices are disabled.
Unfortunately, the EISY logs don’t seem to indicate when or how the Insteon devices were disabled, but seeing as I and Home Assistant are the only two users with access to the EISY, and I certainly didn’t disable those devices–along with the consideration that the Insteon devices turn off, without human interaction, at the same time the Unifi services are paused, I make the reasonable assumption that this is all happening simultaneously as a result of a common cause. All evidence seems to point to HA being the culprit.
I’ve read another post that seemed to attribute similar behavior to an Alexa routine. I don’t have an Alexa in my setup, don’t want one anywhere near it to be honest. I have no automation controllers aside from HA and the EISY. The EISY doesn’t have the ability to access my Unifi to be able to do anything, so I know it’s not originating there. As for HA, I have no automations that affect my Unifi Network at all. The closest thing I have involves changing some ViewPorts’ views based on motion, but they are handled through Unifi Protect which is a separate integration from Unifi Network.
The Unifi logs are clear that it is HA that is doing the pausing, identifying both the assigned HA user and HA ip address.
Any thoughts?
