I have setup HA at home a few minutes after rebooting, HA is not reachable nor can I ping the ip address on the network. Given that I didn’t have a proper display port cable at home I brought the PC to the office to check what was wrong and HA was running uninterrupted on my office network. I have assigned a fixed IP address to HA on my home network from my router, beside that there is no difference in networking or the environment. This behavior started after the latest update, any idea what is going on here?
Edit: My installation is: Sorry I think I wasn’t clear enough HA on Debian on PC Standalone installation no VM.
PC or RPI? I would suggest to restore from a backup and at the same time buy a cable. Then, when you receive the cable, try to upgrade again - if there is an issue you can use the cable to try to investigate?
It is on PC, my monitors at work are DP so I could load it successfully at work and HA is running with no issues at my office, I may need to take one of the cables home to see what loads up on the screen at my home network. However, I am highly confident it has to do with the networking rather than the software as I can’t even ping the PC which HA is running on at home. Perhaps need to fix the IP address on HA rather than my gateway?
