I have setup HassOS with DuckDNS and all works fine via SSL.
However, I have several local servers (.e.g. Node-Red) in need to connect to HA. At moment this works via the external https://xxx.duckdns.org ,
Is it possible to have a feature to enable a HTTP port for trusted local IPs to avoid local connect via public internet?
gpbenton
(Graham)
August 20, 2018, 8:31am
2
If you want this kind of functionality, you need to access your HA via a reverse proxy such as caddy or nginx .
yeah, I was afraid I have to … its just very complex to configure them. Having a local port available would simplify these things dramatically.
But thank you for you Caddy pointer, this looks a good path!
Since you’re on hassio, your best option is to use the hassio api proxy address of http://hassio/homeassistant .
Yuran
(Anders Yuran)
August 21, 2018, 1:09pm
5
Pihole can do that for you. Used as a dns you can easy setup local ip.s so all traffic goues in the LAN for these servers
Yes, routing the local traffic is only half the ticket … unfortunately the SSL setup is avoiding a valid connect and therefore not usable for other local apps servers like Node-red to connect successfully.
The hassio api proxy works for Node-Red even if you use SSL.
It did not work for me , that’s why I started this journey … I will have a look into it
