I want to use from mobile my home assistant local installation running in a docker container on my NAS. How to access the docker homeassistant server from external without exposing the NAS itself to the internet?
Does it work via the paid HA cloud service? For other cloud services I do not need to open any ports on my firewall, hope that applies to HA, too. The NAS itself is not firewalled as it is not shard with the internet. In case I open ports for external access, I think I need to apply proper firewalling.
If I need to expose a port forward, how do I do it with FritzBox and IPv6? I have DSlite and only external IPv6, no IPv4. Any FritzBox IPv6 pro around, who might be able to help out?
A docker install does not include a supervisor or add-on store. In the docker install method, you are the supervisor and if you want to install add-ons, you have to create and link your own docker containers or other installation of the software.
For docker on a NAS, to expose just HA, you will need to setup either DDNS and port forwarding on your router, or a VPN to access internal resources externally.
