Hi
Pulling my hair out on this as cannot for the life of me work out whats going on.
I Install fresh HA virtualised on my QNAP NAS using the Supervised, haos_ova-14.1.ova file → All is good, and I can restore my backup, and access the config interface via http://192.168.20.122:8123
I visit Settings–>System–>Network, select ‘Static’, and set the IP to 192.168.20.30 (outside my DHCP range)
I hit the Save Button and Wait. Result is that I can never again access my HA
No Access on either 192.168.20.30:8123 or the previous IP http://192.168.20.122:8123
I can ping the instance on 192.168.20.30
I have tried restarting the VM, to no avail
I have tried restarting the entire NAS also to no avail
I can see that the VM, has been allocated the IP 192.168.20.30
If I revert to VM snapshot I took before changing the IP then access returns via http://192.168.20.122:8123
If anyone has any idea what might be causing this, please reply. At the moment I am pretty close to simply giving up!
I can only assume that the IP change has only half-taken effect (ha on one IP, supervisor on another?). Is there a configuration file I can modify prior to rebooting HA to effect the same change?
