Followed this guide: How To Install Home Assistant VM - YouTube
Tried 10.3, 10.1, 9.5
Supervisor always stalls trying to install ghcr, 500 server error.
What am I doing wrong?
Your system cannot access GitHub over the Internet. This is a communications issue wither with your LAN, NAT router (Internet gateway), DNS, or cloud related. Check if you have local network issues (DHCP, DNS), if not, the issue is cloud related, try again later.
Thanks for pointing me in the right direction.
TCP (80) was failing to everywhere except GW (FW) due to hardware checksum in virtualized environment.
I spun up a new network to put it in and because my HW FW (pfSense 7100) died and I had to virtualize the FW in XCP-NG. All other interfaces had Disable hardware checksum offload
set already.
I learned a new command though…
curl www.home-assistant.io
