Reconfigure, and choose the correct port instead of the multiprotocol add-on
90 % success… Zigbee works, though 3 of my Zigbee devices do not. I will work on it and let you know. THANKS
Everything seems to work now. Thanks
If you don’t have a second stick for Thread, yes.
It might switch back again, so the recommended way is to use path by is instead.
How does one do that ?
Settings → hardware → All hardware → find your USB device.
You should then see a /dev/serial/by-id/…
Use that. It will stay fixed even if the device switch port.
I did that as well. It is of no use, I think, because there is no Thread anymore after removing multiprotocol.
For me updating to the 16.2 dev build allowed my existing setup to keep working without other changes: ha os update --version 16.2.dev20250814
That worked, thanks
Didn’t work for me. I had to return to the 15.2 ha os in order to reconnect with the zigbee devices on my yellow.
I followed the steps and it worked for me.
