This morning again HA seems lost network. This is what I found in log.
The network is working. dB on nas is working other tools still using their dB
2023-02-25 08:51:17.881 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.885 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration remote_syslog which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.886 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration icloud3 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.887 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.887 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nest_protect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.888 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration fullykiosk which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.888 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration anniversaries which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.893 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration huesyncbox which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.894 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration momentary which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.896 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.898 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hpprinter which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.900 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration asusrouter which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.901 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration worlds_air_quality_index which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.903 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration adaptive_lighting which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:17.905 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-02-25 08:51:20.220 ERROR (Recorder) [homeassistant.components.recorder.core] Error during connection setup: (psycopg2.OperationalError) connection to server at "192.168.100.62", port 5433 failed: Network unreachable
Is the server running on that host and accepting TCP/IP connections?
(Background on this error at: https://sqlalche.me/e/14/e3q8) (retrying in 3 seconds)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3361, in _wrap_pool_connect
return fn()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 325, in connect
return _ConnectionFairy._checkout(self)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 888, in _checkout
fairy = _ConnectionRecord.checkout(pool)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 491, in checkout
rec = pool._do_get()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/impl.py", line 145, in _do_get
with util.safe_reraise():
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/util/langhelpers.py", line 70, in __exit__
compat.raise_(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/util/compat.py", line 211, in raise_
raise exception
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/impl.py", line 143, in _do_get
return self._create_connection()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 271, in _create_connection
return _ConnectionRecord(self)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 386, in __init__
self.__connect()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 684, in __connect
compat.raise_(
raise exception
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 680, in __connect
self.dbapi_connection = connection = pool._invoke_creator(self)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/create.py", line 578, in connect
return dialect.connect(*cargs, **cparams)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/default.py", line 598, in connect
return self.dbapi.connect(*cargs, **cparams)
File "/usr/local/lib/python3.10/site-packages/psycopg2/__init__.py", line 122, in connect
conn = _connect(dsn, connection_factory=connection_factory, **kwasync)
psycopg2.OperationalError: connection to server at "192.168.100.62", port 5433 failed: Network unreachable
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 704, in _setup_recorder
self._setup_connection()
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1175, in _setup_connection
Base.metadata.create_all(self.engine)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/sql/schema.py", line 4930, in create_all
bind._run_ddl_visitor(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/future/engine.py", line 341, in _run_ddl_visitor
with self.begin() as conn:
File "/usr/local/lib/python3.10/contextlib.py", line 135, in __enter__
return next(self.gen)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/future/engine.py", line 379, in begin
with self.connect() as conn:
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/future/engine.py", line 406, in connect
return super(Engine, self).connect()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3315, in connect
return self._connection_cls(self, close_with_result=close_with_result)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 96, in __init__
else engine.raw_connection()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3394, in raw_connection
return self._wrap_pool_connect(self.pool.connect, _connection)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3364, in _wrap_pool_connect
Connection._handle_dbapi_exception_noconnection(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 2198, in _handle_dbapi_exception_noconnection
util.raise_(
raise exception
return fn()
compat.raise_(
raise exception
self.__connect()
compat.raise_(
raise exception
sqlalchemy.exc.OperationalError: (psycopg2.OperationalError) connection to server at "192.168.100.62", port 5433 failed: Network unreachable
2023-02-25 08:51:23.259 ERROR (Recorder) [homeassistant.components.recorder.core] Error during connection setup: (psycopg2.OperationalError) connection to server at "192.168.100.62", port 5433 failed: Network unreachable
return fn()
compat.raise_(
raise exception
self.__connect()
compat.raise_(
raise exception
util.raise_(
raise exception
return fn()
compat.raise_(
raise exception
self.__connect()
compat.raise_(
raise exception
2023-02-25 08:51:27.838 ERROR (MainThread) [homeassistant.components.hassio.addon_panel] Can't read panel info: System is not ready with state: setup
2023-02-25 08:51:28.088 ERROR (MainThread) [homeassistant.setup] Error during setup of component hassio
File "/usr/src/homeassistant/homeassistant/setup.py", line 256, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 587, in async_setup
await repairs.setup()
File "/usr/src/homeassistant/homeassistant/components/hassio/repairs.py", line 149, in setup
await self.update()
File "/usr/src/homeassistant/homeassistant/components/hassio/repairs.py", line 157, in update
data = await self._client.get_resolution_info()
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 51, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: System is not ready with state: setup
2023-02-25 08:52:05.764 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of raspberry_pi. Setup failed for dependencies: hassio
2023-02-25 08:52:05.766 ERROR (MainThread) [homeassistant.setup] Setup failed for raspberry_pi: (DependencyError(...), 'Could not setup dependencies: hassio')
2023-02-25 08:54:17.015 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /homeassistant/restart request Server disconnected
