Is this a Raspberry Pi?
Yes, RPI4 using 256Gb USB SSD
You’re running the wrong script.
Try this one
bash -c "$(wget -qLO - https://github.com/tteck/Proxmox/raw/main/vm/pimox-haos-vm.sh)"
Super that worked, apologies for the miss, and thanks for supporting so quickly!
Hi @austin17427 what were the drawbacks that made you move back to bare metal? Regards,
Plz Update pveversion check to work on 7.4 ---->
if [ $(pveversion | grep -c “pve-manager/7.[2-9]”) -eq 0 ]; then
Thank you for bringing this to my attention. The issue has since been resolved.
What I noted above (HA being the noisy neighbor) was the compelling reason in going bare-metal. Also I couldn’t use Pi native stuff like “Raspberry Pi Power Supply Checker”. I had to pass the bluetooth device “ASUS USB-BT500” as a device to the vm. Another big reason was I had a 2GB Pi laying around. I don’t know if those answer your question or apply to your use case.
Hi tteck - I tried the script you provided for RPI4 and it does not do anything. Does the VM still exist? Thanks for any advice and your work on this.
Yep,
Thanks for the reply tteck. I am getting the below error re: “cannot set up guest memory 'mach-virt.ram”…
Creating a HAOS VM using the above default settings
✓ Using local for Storage Location.
✓ Virtual Machine ID is 100.
✓ https://github.com/home-assistant/operating-system/releases/download/10.3/haos_generic-aarch64-10.3.qcow2.xz
✓ Downloaded haos_generic-aarch64-10.3.qcow2.xz
✓ Extracted Disk Image
✓ Created HAOS VM (haos10.3)
- Starting Home Assistant OS VM…kvm: cannot set up guest memory ‘mach-virt.ram’: Cannot allocate memory
start failed: QEMU exited with code 1
ERROR 255@324 Unknown failure occurred.
This error can occur when there is insufficient memory available on the host system to allocate to the virtual machine.
Thanks again - trying to install on a RPi 4 with 4GB. It is a clean install with nothing else added. I read the default is 4GB so will look it I can change that to 2GB.
Is anyone running this successfully? I’m tempted to give it a try but I’d like to have some confidence that it might be worth investing the time.
same problem here:
Creating a HAOS VM using the above advanced settings
✓ https://github.com/home-assistant/operating-system/releases/download/10.5/haos_generic-aarch64-10.5.qcow2.xz
✓ Downloaded haos_generic-aarch64-10.5.qcow2.xz
✓ Created HAOS VM (haos10.5)
Holy Necro I know.
But has anyone solved the “QEMU exited with code 1” issue?
I’ve followed multiple guides but still not coming right.
Even using @tteck script I get “This version of Proxmox Virtual Environment is not supported
Requires PVE7 Version 7.4-13 or later, or PVE8 Version 8.1.1 or later.”
But from what I can find, PiMox stopped support at 7.2-7 (unless I’m missing a new version somewhere)
Sorry about that, function PVE_CHECK()
is now fixed.
Hello @tteck, I have used your script to have HAOS running on pimox, and I have tried to do some USB port passthrough for a RCP for my openThread Border Router. Even though I think Iam doing this correctly I can’t seem to make the vm start whenever I do my forwarding. This is the message I get:
kvm: Warning: speed mismatch trying to attach usb device “Thread Co-Processor” (full speed) to bus “ehci.0”, port “3” (high speed)
start failed: command ‘/usr/bin/kvm -id 100 -name ‘haos12.2,debug-threads=on’ -no-shutdown -chardev ‘socket,id=qmp,path=/var/run/qemu-server/100.qmp,server=on,wait=off’ -mon ‘chardev=qmp,mode=control’ -chardev ‘socket,id=qmp-event,path=/var/run/qmeventd.sock,reconnect=5’ -mon ‘chardev=qmp-event,mode=control’ -pidfile /var/run/qemu-server/100.pid -daemonize -smbios ‘type=1,uuid=66e4a2cf-eba5-4a8d-ac44-56bef2a71acf’ -drive ‘if=pflash,unit=0,format=raw,readonly=on,file=/usr/share/pve-edk2-firmware//AAVMF_CODE.fd’ -drive ‘if=pflash,unit=1,format=qcow2,id=drive-efidisk0,file=/var/lib/vz/images/100/vm-100-disk-0.qcow2’ -smp ‘2,sockets=1,cores=2,maxcpus=2’ -nodefaults -boot ‘menu=on,strict=on,reboot-timeout=1000,splash=/usr/share/qemu-server/bootsplash.jpg’ -vnc ‘unix:/var/run/qemu-server/100.vnc,password=on’ -cpu host -m 4096 -device ‘pci-bridge,id=pci.1,chassis_nr=1,bus=pcie.0,addr=0x1e’ -device ‘pci-bridge,id=pci.2,chassis_nr=2,bus=pcie.0,addr=0x1f’ -device ‘usb-ehci,id=ehci,bus=pcie.0,addr=0x1’ -device ‘usb-tablet,id=tablet,bus=ehci.0,port=1’ -device ‘usb-kbd,id=keyboard,bus=ehci.0,port=2’ -device ‘usb-host,vendorid=0x1915,productid=0x0000,id=usb0’ -device ‘virtio-gpu,id=vga,bus=pcie.0,addr=0x2’ -device ‘virtio-serial,id=spice,bus=pcie.0,addr=0x9’ -chardev ‘spicevmc,id=vdagent,name=vdagent’ -device ‘virtserialport,chardev=vdagent,name=com.redhat.spice.0’ -spice ‘tls-port=61000,addr=127.0.0.1,tls-ciphers=HIGH,seamless-migration=on’ -device ‘virtio-balloon-pci,id=balloon0,bus=pcie.0,addr=0x3,free-page-reporting=on’ -device ‘virtio-scsi-pci,id=scsihw0,bus=pcie.0,addr=0x5’ -drive ‘file=/var/lib/vz/images/100/vm-100-disk-1.qcow2,if=none,id=drive-scsi0,format=qcow2,cache=none,aio=io_uring,detect-zeroes=on’ -device ‘scsi-hd,bus=scsihw0.0,channel=0,scsi-id=0,lun=0,drive=drive-scsi0,id=scsi0,bootindex=100’ -netdev ‘type=tap,id=net0,ifname=tap100i0,script=/var/lib/qemu-server/pve-bridge,downscript=/var/lib/qemu-server/pve-bridgedown,vhost=on’ -device ‘virtio-net-pci,mac=00:60:2F:A3:A5:9A,netdev=net0,bus=pcie.0,addr=0x12,id=net0’ -machine ‘type=virt+pve0’’ failed: got timeout
Does someone have an idea what I can do to solve this ?
Hello ,
I’ve installed pimox, successfull, and run the command to install home assisttant but I can’t access to homeassistant.local:8123.
Strangely I can access to homeassistant.local:4357
Home Assistant observer
Supervisor: | Connected |
Supported: | Supported |
Healthy: | Healthy |
But I can’t connect to 8123 …
In the console withe ha network info , I’ve this :
I think it’s a part of he solution, maybe the docker address or gateway is in conflict…
Anyone an idea ?..
I am currently facing the exact same issue. Has anyone found a solution to this? I can’t connect over homeassitant.local:8123 or via my IP.
However, it worked perfectly before restoring from back-up. It seems that something in my back-up restore is causing this issue. I believe it may be related to home assistant core in my back-up, but I am not sure what or how.
My back-up was from a system where HAOS was directly installed on an SD for my RPI.
