HA OS Signal Integration
Updated 8/14/2024
I have successfully installed Signal Messenger Add-On into HA OS. Here is how I did it.
HA OS info:
Core                2024.8.1
Supervisor          2024.08.0
Operating System    13.0
Frontend            20240809.0
Signal Addon        0.88.0 (This version fixed registration issues)
Guide I followed: Signal Messenger - Home Assistant
Rest API configuration Steps:
  • Installation Method: ALT 2 / Install Home Assistant Add On
    – Signal add-on Options: JSON-RPC & port 8080
  • Setup Phone Number: ALT 1 / Use a new phone number (Google Voice number will accept SMS)
  • Trouble shooting: A captcha is required (due to a captcha being required during registration)
Registration Steps:
  • In a browser such as Chrome/Firefox, Navigate to: Signal to get captcha token.
  • When you answer the captcha, the browser may try and open Signal automatically, click “cancel” and an “Open Signal” link will show up under the captcha. Right click that link and copy the link address and save that link in notes.
  • In HA SSH session, enter the following:
Note 1: all hash’s have been obscured and is there for information purposes only.
Note 2: Sometimes the Captcha site will give you a huge link with the captcha information, I have not tested with this type of response as the first response I got was the shortened captcha token.
curl -X POST -H "Content-Type: application/json" -d '{"captcha":"signalcaptcha://signal-hcaptcha-short.5fad97ac-7d06-4e44-b18b-c556b20148ff.registration.4o_23jhtgjr30QnHSqCd2atQ", "use_voice": false}' 'http://55.55.55.55:8080/v1/register/+13335557777'
  • The above syntax shows the specific way you are supposed to add the captcha information. I added the entire URL copied and that worked. You then list the IP address of HA and the port Signal API is listening on followed by the phone number you are trying to register.
  • Once you enter that command you should receive an SMS code to use as a verification. (this portion was broke prior to 0.88.0)
  • Enter the verification code in the CLI as follows:
curl -X POST -H "Content-Type: application/json" 'http://55.55.55.55:8080/v1/register/+13335557777/verify/123456'
  • The verification code has a hyphen in it, but I did not use it during the verification process.
  • As long as no errors came up, Signal API is setup. To verify your account is setup enter:
curl -X GET -H "Content-Type: application/json" 'http://55.55.55.55:8080/v1/accounts'
It should respond with your phone number in brackets. [“+13335557777”]. This means you are good for this portion of the guide and can go back to HA main integration page to setup the YAML.
YAML Setup:
notify:
  - name: signal
    platform: signal_messenger
    url: "http://55.55.55.55:8080"
    number: "+13335557777"
    recipients:
      - "+14445559999"
  • YAML is very picky with spaces. Once you save this in the configuration.yaml and restart HA, you will now see the Signal Integration show up under Integrations if the YAML was done properly. Keep in mind if you dont setup the YAML properly as far as formatting goes, the integration will not show up after a reboot.
Example of Good YAML config with multiple notify platforms:
notify:
  - platform: html5
    vapid_pub_key: [pubkeyinfo]
    vapid_prv_key: [prvkeyinfo]
    vapid_email: [Email]
  - name: signal
    recipients:
      - "+14445559999"
Example of BAD YAML config with multiple notify platforms. Only html5 notify section will show up in integrations:
notify:
  - platform: html5
notify:
  - name: signal
    recipients:
      - "+14445559999"
  • Send a test message with:
curl -X POST -H "Content-Type: application/json" 'http://55.55.55.55:8080/v2/send'  -d '{"message": "This is a test message from Home Assistant!", "number": "+13335557777", "recipients": [ "+14445559999" ]}'
Hopefully this helps everyone get Signal setup on HA OS!
Hello. Thanks for this tutorial. It is really helpful.
After many attempts, I was able to register my landline number with Signal and received it as a response when I checked my account.
When I then tried to send a test message as described, I received the response “error”:“Failed to send message”.
I’m using Signal version 0.91.0
My YAML setup:
notify:
  • name: signal
    url: “http://192.168.xxx.xxx:7465
    number: “+49561xxxxxxxxx”
    recipients:
    • “+49151yyyyyyyy”
My test message:
curl -X POST -H “Content-Type: application/json” ‘http://192.168.xxx.xxx:7465/v2/send’ -d ‘{“message”: “This is a test message from Home Assistant!”, “number”: “+49xxxxxxxxxxx”, “recipients”: [ “+49yyyyyyyyyyy” ]}’
Do you know any reason for this error?
Just wanted to quickly say Thanks to @xXSubZ3r0Xx - This tutorial helped a lot to get it up and running.
hey there,
I always get
{“error”:“Invalid captcha given.\n”}#
when I create a captcha it is really long, did you shortenend it?
signalcaptcha://signal-hcaptcha.5fad97ac-7d06-4e44-b18a-b950b20148ff.registration.P1_eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.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.AJRp0c6W5RDp8GKLNoo0ySHp8t322KtoencBWrksvx8
this is a original code from signal, I try to use a landline number from germany.
I followed these instructions. Thank your for this.
I only get this in return from the api:
{"error":"Failed to register: StatusCode: 502 (ExternalServiceFailureException)\n"}#
I wonder if the failure is on my side or if someone on the signal end has changed something.
My Signal notifications stopped working after nearly two years with
Error: Specified account does not exist
No clue why this happened but thanks to the instructions on this post I managed to reactivate my account and everything is working as before.
used terminal in ha to send registration request with the massive long token and it worked flawlessly.
Thanks for sharing this.
Is there any way to use my own phone number, which is already registered in the Signal app in my iPhone? My main goal is to use this integration to send notifications to a group formed by my wife and I.
Once again my account seems to have been removed a few days ago.
found Error: Specified account does not exist in HA logs
therefore re-run registration steps from initial post and notifications are working again.
Had to do the captcha thing twice as the first attempt gave me an authentication error…
Also have the mobile that you register up and running to get the verification code.
