After updating to HA OS 6.0 I wanted to revert to a previous version (found serious bugs), but the command
ha os update --version 5.xx
gives me the following error for any version:
Error raised from OTA webserver: 404
How can I solve this?
ha host update --version 5.13
EDIT: This is wrong.
It’s ha os update --version 5.13
Thanks for the very quick answer,
works
Interesting. That must be a legacy command left in for backward compatibility. The currently documented command is definitely ha host update
See: https://www.home-assistant.io/common-tasks/os#host
Yeah I was a bit confused, I will stick with ha host update
for now on.
“host update” is an alias to “host reload”, see host update --help
Well crap. That was bad advice. Sorry.
Ok, so I want to revert to 5.4 (the only stable version for me). The command
ha host update --version 5.4
Gives me an error, since flag --version does not exist
ha os update
(the one I used in the past) only works for 5.13
Yeah I was wrong. The command is ha os update
You can still downgrade with USB https://github.com/home-assistant/operating-system/blob/44cca729f0d3e91614965deb87429a123c4050b8/Documentation/configuration.md#automatic
A post was split to a new topic: Downgrade core on HAOS
