I have a dev instance of HA setup with no components loaded other than frontend. Because of this there is very little flowing by when you manually start homeassistant.
I noticed that the IP of the computer accessing the front end is displayed each time the front end is loaded.
Can this output be monitored and output to a file or by a sensor?
