Issue
Lately I’m facing a weird issue on my windows laptop. I use Chrome to connect to my ha instance.
Sometimes it loads forever. I can see the loading ha logo, but nothing happens. When I try it again seconds/minutes later it works fine again.
There are no errors or warnings in the logs pointing to this.
"Workaround"
This issue happens daily on that single laptop, but I remember that I had similar issues with my iPhone too. In this case it helped to switch to 4G and back to Wifi.
This is why I tried connecting my laptop to a hotspot of my phone today while it was loading forever (stuck). The page immediately poped up, but with the message “Reload lovelace”. Clicked it and works.
Details:
The laptop has no issues loading other webpages. The wifi signal is perfect.
I run hassio on a raspi 4 with ha 0.101.3. I use pihole and duckdns as addons. And it has a static local IP
the CPU usage of my pi4 seems fine. Idles around 10% with a few spikes up to 50%.
I use the same url in and outside my network. To achieve this pihole redirects the public url to the local IP.
I think the issue has something to do with the redirection, but I ran out of ideas. -
using a UniFi network
configuration of Pihole:
"update_lists_on_start": true,
"ssl": true,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem",
"interface": "eth0",
"ipv6": true,
"ipv4_address": "",
"ipv6_address": "",
"virtual_host": "myduckdns.duckdns.org",
"hosts": [
"name": "myduckdns.duckdns.org",
"ip": "192.168.0.2"
"log_level": "info"
Would appreciate any idea. Thanks!
