Try to upgrade my core (RPi 3b) HA to Python 3.10.
I’ve installed Python successful. Both Python --version and Python3 --version return 3.10.9
Use this instruction to upgrade Upgrading HomeAssistant Core in a Python VE
During the installation process it get “error: metadata-generation-failed”. See below for details.
Google search is not helpful.
Any suggestions?
/edit/ added more error details
Preparing metadata (setup.py) ... error
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [55 lines of output]
/usr/local/lib/python3.10/site-packages/setuptools/config/setupcfg.py:508: SetuptoolsDeprecationWarning: The license_file parameter is deprecated, use license_files instead.
warnings.warn(msg, warning_class)
/usr/local/lib/python3.10/site-packages/setuptools/installer.py:27: SetuptoolsDeprecationWarning: setuptools.installer is deprecated. Requirements should be satisfied by a PEP 517 installer.
warnings.warn(
WARNING: The wheel package is not available.
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [8 lines of output]
usage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: setup.py --help [cmd1 cmd2 ...]
or: setup.py --help-commands
or: setup.py cmd --help
error: invalid command 'bdist_wheel'
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for cffi
ERROR: Failed to build one or more wheels
File "/usr/local/lib/python3.10/site-packages/setuptools/installer.py", line 82, in fetch_build_egg
subprocess.check_call(cmd)
File "/usr/local/lib/python3.10/subprocess.py", line 369, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/usr/local/bin/python3.10', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpvm34_xs0', '--quiet', 'cffi>=1.12.0']' returned non-zero exit status 1.
File "<string>", line 2, in <module>
File "<pip-setuptools-caller>", line 34, in <module>
File "/tmp/pip-install-l7x3dhh_/miniaudio_23fa9dae39094761a8bebff39e06ce39/setup.py", line 20, in <module>
setup(
File "/usr/local/lib/python3.10/site-packages/setuptools/__init__.py", line 86, in setup
_install_setup_requires(attrs)
File "/usr/local/lib/python3.10/site-packages/setuptools/__init__.py", line 80, in _install_setup_requires
dist.fetch_build_eggs(dist.setup_requires)
File "/usr/local/lib/python3.10/site-packages/setuptools/dist.py", line 875, in fetch_build_eggs
resolved_dists = pkg_resources.working_set.resolve(
File "/usr/local/lib/python3.10/site-packages/pkg_resources/__init__.py", line 789, in resolve
dist = best[req.key] = env.best_match(
File "/usr/local/lib/python3.10/site-packages/pkg_resources/__init__.py", line 1075, in best_match
return self.obtain(req, installer)
File "/usr/local/lib/python3.10/site-packages/pkg_resources/__init__.py", line 1087, in obtain
return installer(requirement)
File "/usr/local/lib/python3.10/site-packages/setuptools/dist.py", line 945, in fetch_build_egg
return fetch_build_egg(self, req)
File "/usr/local/lib/python3.10/site-packages/setuptools/installer.py", line 84, in fetch_build_egg
raise DistutilsError(str(e)) from e
distutils.errors.DistutilsError: Command '['/usr/local/bin/python3.10', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpvm34_xs0', '--quiet', 'cffi>=1.12.0']' returned non-zero exit status 1.
[end of output]
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
