Hello Guys.
I’m having this problem:
HA restarts randomly by itself. I cannot see a pattern.
I read that the symptom might be caused by a bad SD card. Mine was 18 months old, so I replaced it but the problem persists.
When I replaced the SD I installed a new 64bits installation and uploaded the restore file. I’m using a Raspberry Pi 3B+
Here you can see how often it happens.
In the meantime, while I was getting the new SD card I ran it in a VM, and I didn’t see the problem. I’m not sure if it happened and I didn’t see it or it didn’t happen.
I can’s see anything in supervisor logs either
Maybe the RPI is not stable? Any ideas?
Thanks in advance.
BR
