Hi!
Anyone knows a good information in order to renew my certificates? I tried everything on google, nothing works… sudo command not found. Certbot error, how can I do it manually?
Hi!
I am using it, but this addon didn’t autorenew the certificate… Thats why I try to find another way…
I think I solve it, I not 100% sure… I just regenerate the token from duckdns…
Nope: NET::ERR_CERT_DATE_INVALID
Update: It seems that now it is VALID… after a HA restart… BUT still, I don’t know the exact process in order to renew it again, next time… What should I do? Regenerate the token from duckdns, add it to the addon and restart HA? :))) Kinda a mess
How odd… can you post your config? Just leave out the token and domain
Interesting. I wouldn’t think you would need to generate a new token each time. It should just check your certificates validity every now and then and renew it when it’s getting old.
I haven’t used it in a while now, since I moved to DNS-01 challenges, so maybe someone with a current config could confirm?
Nothing. it should update automatically. I’ve been using DuckDNS for 3 years and have never had to touch it.
It used to require port 80 be forwarded in your router but that is no longer a requirement.
You should have this in your addon config:
lets_encrypt:
accept_terms: true
certfile: fullchain.pem
keyfile: privkey.pem
If you do, then maybe something is blocking the connection in your router?
Check your router logs.
I have the same config… And the router have two forwards, 443 and 80. No bad logs into the router
Then it should renew the certificates automatically.
Yes, but I don’t know why haven’t already… I just woke up in the morning, no automation then I see that I can’t access home assistant and nothing… Good that I had the Share on and SSH, to turn off SSL till I solve it
Interesting, have a read of this issue:
That would certainly explain it. Do either of the Nginx addons restart their respective web servers after obtaining new certificates? I have dehydrated restart my web server via hooks whenever a new cert is issued but that doesn’t really work in a Home Assistant environment…
I don’t know enough about NGINX to say, sorry.
