I try to restart HA from "Server Control"t - “Server management” menu. but returns an error:
Logger: homeassistant.core
Source: helpers/config_validation.py:793
First occurred: 11:53:19 PM (2 occurrences)
Last logged: 11:54:28 PM
Error executing service: <ServiceCall homeassistant.restart (c:017f4c200b4311ebb1a561c4016c44c2)>
Error executing service: <ServiceCall homeassistant.restart (c:2ae3d3880b4311eb94dfe5476290ab71)>
File "/usr/src/homeassistant/homeassistant/core.py", line 1351, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1370, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 360, in async_handle_core_service
errors = await conf_util.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/config.py", line 865, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 129, in async_check_ha_config_file
config = config_schema(config)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
cval = cvalue(key_path, value)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 469, in verify
return cast(Dict, schema(value))
return schema(data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 215, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 338, in _exec
v = func(path, v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 635, in validate_sequence
cval = validate(index_path, value)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 882, in script_action
return ACTION_TYPE_SCHEMAS[determine_script_action(value)](value)
v = func(path, v)
v = func(path, v)
return schema(data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 260, in _exec
return func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 793, in key_value_validator
if key_value not in value_schemas:
TypeError: unhashable type: 'collections.OrderedDict'```
