Hi folksl
I have installed HA now for my third time. The first time, I was doing great. I installed all kinds of apps. In that first installation, HA also said it was not healthy, but I guess it fixed itself because that msg went away. My problems started when I tried to install Duckdns. No matter what I did, I could not get back in. Never did. I decided instead to start over. This is where I am now. I started over and HA is working, but it gives that same error. System not healthy. I looked into it and it says HA is not privileged and that the system is not supported. That I should install HA under a supported OS like Debian. I’m looking into that presently.
Anyway, a couple of questions:
- Where does HA get the IPs that it gives to run the UI from? This time it gave http://10.211.55.10:8123. That is not my IP. When I try to run HA from my IP, it does not run. I believe that was a part of the problem when I was debugging the problems with Duckdns.
- Should I just try to update HA with the OS I have running which is Ubuntu 20.04? I cannot do it from the UI, there’s no button or option for it like someone has said on this forum.
- Is the health problem going to fix itself or should I pursue that? Here is a screenshot of my system:
Screen Shot 2021-03-31 at 4.13.37 PM|690x353
Any advise would help me determine what i should do or path to take.
