HA says update available but its already up to date?
I have a problem where HA keeps saying one of my ESPHome devices is not up to date and I have no idea why?
Telling it to skip just makes it come back next time there’s an update. Saying install does nothing.
All the others (including the bt_proxy_dining_room that is identical YAML) work fine and tell me only when there’s an update and goes away when they have been updated.
Under settings:
But then for the device integration page it says:
And on the ESPHome dashboard says no updates needed:
Logs:
INFO Reading configuration /config/esphome/esp32_bt_proxy_garage.yaml...
WARNING 'bt_proxy_garage': Using the '_' (underscore) character in the hostname is discouraged as it can cause problems with some DHCP and local name services. For more information, see https://esphome.io/guides/faq.html#why-shouldn-t-i-use-underscores-in-my-device-name
WARNING GPIO2 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Starting log output from bt_proxy_garage.apt using esphome API
INFO Successfully connected to bt_proxy_garage.apt
[16:33:29][I][app:102]: ESPHome version 2023.2.3 compiled on Feb 20 2023, 16:24:57
Anyone? Ideas?
Hello good morning, I have the same problem, could you find a solution?
Still no known solution here :frowning:
I’ve been for now just avoiding updating ESPHome…and got it one time somehow to go away manually using USB to reflash firmware on the ones that were stuck (but they come back next update) so my “fix” is I no longer update ESPHome.
