HA sees zigbee lights that are off as "on" with 100 percent brightness, breaking 'light: turn on' automation
This makes toggling lights ‘off’ possible, but turning them back ‘on’ is impossible because HA sees the light as ‘on’ already. When I use the ‘light’ card in overview, I toggle the lights off and I can see the brightness slider briefly go to 0 percent, and then jump back to 100 percent. Any ideas?
How are you running Zigbee, and what does the logs say?
same strange problem here…
Is there anything in the history for the bulb that gives you a hint?
