I have set up a working IR-transmitter using a ESP Wrover Kit, running Arduino Latest.
As shown in the Documentation I can import sensor data, from HA in my code to let it show ambient temperature in the climate card of this entity, but no matter what I do, it will only show 0 degrees - which is annoying.
In logs the sensor data I am interested in shows up as it should.
Here’s my code:
pin: 33
carrier_duty_percent: 50%
- platform: homeassistant
entity_id: sensor.atc_43f8_temperature
unit_of_measurement: "°C"
device_class: "temperature"
state_class: "measurement"
accuracy_decimals: 1
climate:
- platform: mitsubishi
set_fan_mode: "quiet_4levels"
supports_dry: "true"
supports_fan_only: "true"
horizontal_default: "left"
vertical_default: "down"
sensor: temperatur_stue
Any Ideas?
My Log looks like this:
INFO ESPHome 2024.3.2
INFO Reading configuration /config/esphome/stue-media.yaml...
INFO Starting log output from 192.168.0.137 using esphome API
INFO Successfully connected to stue-media @ 192.168.0.137 in 0.107s
INFO Successful handshake with stue-media @ 192.168.0.137 in 0.087s
[16:48:50][I][app:102]: ESPHome version 2024.3.2 compiled on Apr 8 2024, 16:43:27
[16:48:50][C][wifi:580]: WiFi:
[16:48:50][C][wifi:408]: Local MAC: B0:B2:1C:51:EF:C8
[16:48:50][C][wifi:413]: SSID: [redacted]
[16:48:50][C][wifi:416]: IP Address: 192.168.0.137
[16:48:50][C][wifi:420]: BSSID: [redacted]
[16:48:50][C][wifi:421]: Hostname: 'stue-media'
[16:48:50][C][wifi:423]: Signal strength: -39 dB ▂▄▆█
[16:48:50][C][wifi:427]: Channel: 6
[16:48:50][C][wifi:428]: Subnet: 255.255.255.0
[16:48:50][C][wifi:429]: Gateway: 192.168.0.1
[16:48:50][C][wifi:430]: DNS1: 192.168.0.1
[16:48:50][C][wifi:431]: DNS2: 192.168.0.1
[16:48:50][C][logger:166]: Logger:
[16:48:50][C][logger:167]: Level: DEBUG
[16:48:50][C][logger:169]: Log Baud Rate: 115200
[16:48:50][C][logger:170]: Hardware UART: UART0
[16:48:50][C][psram:020]: PSRAM:
[16:48:50][C][psram:021]: Available: YES
[16:48:50][C][psram:024]: Size: 4095 KB
[16:48:50][C][restart.button:017]: Restart Button 'Restart'
[16:48:50][C][remote_transmitter:015]: Remote Transmitter...
[16:48:50][C][remote_transmitter:016]: Channel: 0
[16:48:50][C][remote_transmitter:017]: RMT memory blocks: 1
[16:48:50][C][remote_transmitter:018]: Clock divider: 80
[16:48:50][C][remote_transmitter:019]: Pin: GPIO33
[16:48:50][C][remote_transmitter:022]: Carrier Duty: 50%
[16:48:50][C][climate_ir:076]: IR Climate 'Varmepumpe'
[16:48:50][C][climate_ir:077]: Min. Temperature: 16.0°C
[16:48:50][C][climate_ir:078]: Max. Temperature: 31.0°C
[16:48:50][C][climate_ir:079]: Supports HEAT: YES
[16:48:50][C][climate_ir:080]: Supports COOL: YES
[16:48:50][C][mdns:115]: mDNS:
[16:48:50][C][mdns:116]: Hostname: stue-media
[16:48:50][C][ota:096]: Over-The-Air Updates:
[16:48:50][C][ota:097]: Address: stue-media.local:3232
[16:48:50][C][ota:100]: Using Password.
[16:48:50][C][ota:103]: OTA version: 2.
[16:48:50][C][api:139]: API Server:
[16:48:50][C][api:140]: Address: stue-media.local:6053
[16:48:50][C][api:142]: Using noise encryption: YES
[16:48:50][C][homeassistant.sensor:030]: Homeassistant Sensor 'temperatur_stue'
[16:48:50][C][homeassistant.sensor:030]: Device Class: 'temperature'
[16:48:50][C][homeassistant.sensor:030]: State Class: 'measurement'
[16:48:50][C][homeassistant.sensor:030]: Unit of Measurement: '°C'
[16:48:50][C][homeassistant.sensor:030]: Accuracy Decimals: 1
[16:48:50][C][homeassistant.sensor:031]: Entity ID: 'sensor.atc_43f8_temperature'
[16:48:50][C][audio:203]: Audio:
[16:48:50][C][audio:225]: External DAC channels: 1
[16:48:50][C][audio:226]: I2S DOUT Pin: 14
[16:48:52][D][homeassistant.sensor:024]: 'sensor.atc_43f8_temperature': Got state 23.58
[16:48:52][D][sensor:094]: 'temperatur_stue': Sending state 23.58000 °C with 1 decimals of accuracy
[16:48:52][D][climate:396]: 'Varmepumpe' - Sending state:
[16:48:52][D][climate:399]: Mode: HEAT
[16:48:52][D][climate:404]: Fan Mode: AUTO
[16:48:52][D][climate:410]: Preset: NONE
[16:48:52][D][climate:416]: Swing Mode: OFF
[16:48:52][D][climate:425]: Target Temperature: 23.00°C
