xenia-09A
(Xenia 09 A)
September 13, 2024, 11:29am
1
Hi is the shelly BLU gateway supported on HA GREEN?
2024.8.2
https://www.shelly.com/en-us/products/shop/shelly-gateway
starting here
o add the Bluetooth integration to your Home Assistant instance, use this My button:
HA returns
No unconfigured Bluetooth adapters found. There are 0 ignored adapters.
HA instructions are a bit unclear for me on what to do thanks in advance for any help!!
apreick
September 13, 2024, 1:02pm
2
You only need to supply this Shelly BLE gateway with power.
Then you have to configure it (WLAN access)
The internal Shelly integration should then find it.
Now you just have to configure it like this (passive scan)
Then a script is sent to the Shelly and should work
xenia-09A
(Xenia 09 A)
September 14, 2024, 9:17am
3
hello thanks, so there seems there is no way to not use wifi with the USB gateway as wifi is needed to add into HA via shelly integration
I like to not use wifi and have connected directly USB to HA, so I may need a diff BT GW…
