HA slow after few hours. After restart its pretty fast again for couple hours
Hello, I have the problem that my HA becomes very slow after a few hours. After I restart it, everything in HA loads extremely quickly again. Then after a few hours the process repeats itself, so I have to restart again and again to keep it running quickly. I hope there are some smart people here who can effectively help me with my problem. I thank you in advance.
Can you post your logs after it slows down?
You will have to give more info on this.
What installation are you using?
What is your hardware spec?
And the rest others told you.
Logger: roborock.local_api
Source: runner.py:188
First occurred: 14:51:14 (3404689 occurrences)
Last logged: 17:44:48
[Roborock S7] [Errno 104] Connection reset by peer
[Roborock S7] id=1 Timeout after 4 seconds
[Roborock S7] [Errno 32] Broken pipe
[Roborock S7] maximum recursion depth exceeded
[Roborock S7] Failed connecting to 192..........
are many of some Warning and errors.
Have you tried restarting with that integration disabled to ensure it then works quickly (i.e. it is definitely this integration causing your problems)?
I just uninstalled the Roborock integration and Iā€™m still getting errors with the name Roborock, how can that be? Is it only effective if I restart it with the integration deleted? I could try that out.
Same here: Logger: roborock.local_api
Source: custom_components/roborock/coordinator.py:82
Integration: Roborock (documentation, issues)
First occurred: 15:30:40 (567 occurrences)
Last logged: 17:48:39
I think thats the issue:
Source: custom_components/roborock/coordinator.py:93
First occurred: 14:51:18 (4121 occurrences)
Last logged: 18:02:35
[Roborock S7] Failed connecting to 192ā€¦
is there something i can delete beside the roborock integration ?
I would then start it again
Remove integration and restart home assistant to finish removing integration.
If this works use roborock integration from hacs.
Oke the endless recursion calls from Roborock have led to these freezes.
I would like to thank you for your help!
Now I will try to integrate the roborock integration properly
