Just as Info in case someone had similar problems
I wanted to get the values of a sensor that measures the electricity consumed, sold and heatpump 1 day ago, 2 days ago and 3 days ago. The sensors used as base resets to 0 at midnight.
I was using the code suggested in the SQL Integration page. It was working and then stopped. Couldn’t find why since I hadn’t changed anything - just updated HA to the latest UI and core.
Here is the code that works now - example for electricity, and getting the values for 2 days ago
SELECT
states.state
FROM
states
INNER JOIN states_meta ON
states.metadata_id = states_meta.metadata_id
WHERE
states_meta.entity_id = 'sensor.from_netz_daily'
AND last_updated_ts <= strftime('%s','now','-1 day','start of day')
AND last_updated_ts >= strftime('%s','now','-2 day','start of day')
ORDER BY
CAST(states.state as numeric) DESC
LIMIT
1;
Just for reference, here is the code I had used before. Basically I now use an interval and I use orderer by states.state and CAST.
SELECT
states.state
FROM
states
WHERE
AND last_updated_ts <= strftime('%s', 'now', '-1 days', 'start of day', 'utc')
ORDER BY
last_updated_ts DESC
LIMIT
1;
