Yesterday I have updated my home assistant on my rapsberry pi 5 all was ok all working, until today when I add wifi connection, before I was on cable.
Also that work too, I put lan cable out it connect on wifi and than pluged in and it was lan connection. But suddenly there was no connection and when I plug power out and again in no web acces. I have SSH acces and that is all.
here is log
What address you use to connect?
Is router blocking?
no that was working in lokal network, after chatgpt and some things, at last rebuild, it starts to work but MQTT still didn’t so I deleted 2 folders and MQTT started. I really don’t know why this happend I can’t have wifi connection as redundance if lan fails?
Networking issues? Consider assigning a static IP address to your RaspberryPi in the DHCP section of your router for consistent access results. Be aware if you have WiFi as well as Ethernet connected at the same time, the two MAC addresses cannot be talking on the same IP address. One or the other.
Comment: Ethernet is usually and consistently reliable and most likely significantly faster than WiFi.
I thought I can have both for redundance or backup if one fails another will take over
