I’m about to change the logging level to get more info from it.
Yes, I’ve tried the upgrade several times using the process I detailed in my first post. Unless there has been a new version in the last couple of days though, it has not helped. I can try again after I change the log level settings though.
I think this increased log level will be the first real thing that might shine more light on what is going wrong. At least I hope it shines more light on it.
OK, here is the log from restart to web page timeout.
2023-12-03 20:35:29.356 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds
2023-12-03 20:35:29.357 INFO (MainThread) [homeassistant.bootstrap] Setting up frontend: {'frontend'}
2023-12-03 20:35:29.370 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2023-12-03 20:35:29.370 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds
2023-12-03 20:35:29.438 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2023-12-03 20:35:29.440 INFO (MainThread) [homeassistant.setup] Setting up http
2023-12-03 20:35:29.442 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds
2023-12-03 20:35:29.447 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds
2023-12-03 20:35:29.457 INFO (MainThread) [homeassistant.setup] Setting up api
2023-12-03 20:35:29.459 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds
2023-12-03 20:35:29.460 INFO (MainThread) [homeassistant.setup] Setting up auth
2023-12-03 20:35:29.460 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds
2023-12-03 20:35:29.467 INFO (MainThread) [homeassistant.setup] Setting up config
2023-12-03 20:35:29.476 INFO (MainThread) [homeassistant.setup] Setting up diagnostics
2023-12-03 20:35:29.485 INFO (MainThread) [homeassistant.setup] Setting up repairs
2023-12-03 20:35:29.485 INFO (MainThread) [homeassistant.setup] Setup of domain repairs took 0.0 seconds
2023-12-03 20:35:29.564 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.1 seconds
2023-12-03 20:35:29.565 INFO (MainThread) [homeassistant.setup] Setup of domain diagnostics took 0.1 seconds
2023-12-03 20:35:29.576 INFO (MainThread) [homeassistant.setup] Setting up file_upload
2023-12-03 20:35:29.577 INFO (MainThread) [homeassistant.setup] Setup of domain file_upload took 0.0 seconds
2023-12-03 20:35:29.618 INFO (MainThread) [homeassistant.setup] Setting up image_upload
2023-12-03 20:35:29.619 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2023-12-03 20:35:29.620 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds
2023-12-03 20:35:29.622 INFO (SyncWorker_3) [homeassistant.loader] Loaded group from homeassistant.components.group
2023-12-03 20:35:29.623 INFO (MainThread) [homeassistant.setup] Setup of domain image_upload took 0.0 seconds
2023-12-03 20:35:29.624 INFO (SyncWorker_0) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
2023-12-03 20:35:29.656 INFO (MainThread) [homeassistant.setup] Setting up search
2023-12-03 20:35:29.656 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds
2023-12-03 20:35:30.319 INFO (MainThread) [homeassistant.setup] Setting up analytics
2023-12-03 20:35:30.321 INFO (MainThread) [homeassistant.setup] Setting up person
2023-12-03 20:35:30.322 INFO (MainThread) [homeassistant.setup] Setup of domain analytics took 0.0 seconds
2023-12-03 20:35:30.324 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.0 seconds
2023-12-03 20:35:30.325 INFO (SyncWorker_0) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio
2023-12-03 20:35:30.326 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2023-12-03 20:35:30.327 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds
2023-12-03 20:35:30.330 INFO (MainThread) [homeassistant.setup] Setting up frontend
2023-12-03 20:35:30.332 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds
2023-12-03 20:35:30.333 INFO (MainThread) [homeassistant.bootstrap] Setting up recorder: {'recorder'}
2023-12-03 20:35:30.335 INFO (MainThread) [homeassistant.setup] Setting up recorder
2023-12-03 20:35:30.344 INFO (MainThread) [homeassistant.components.http] Now listening on port 8123
2023-12-03 20:35:30.373 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.0 seconds
2023-12-03 20:35:30.374 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {'usb', 'webhook', 'api', 'websocket_api', 'http', 'cloud', 'ssdp', 'network', 'zeroconf', 'bluetooth', 'dhcp'}
2023-12-03 20:35:30.388 INFO (MainThread) [homeassistant.setup] Setting up webhook
2023-12-03 20:35:30.388 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds
2023-12-03 20:35:30.406 INFO (MainThread) [homeassistant.setup] Setting up usb
2023-12-03 20:35:30.406 INFO (MainThread) [homeassistant.setup] Setup of domain usb took 0.0 seconds
2023-12-03 20:35:30.410 INFO (MainThread) [homeassistant.setup] Setting up network
2023-12-03 20:35:30.411 INFO (MainThread) [homeassistant.setup] Setup of domain network took 0.0 seconds
2023-12-03 20:35:30.466 INFO (MainThread) [homeassistant.setup] Setting up dhcp
2023-12-03 20:35:30.466 INFO (MainThread) [homeassistant.setup] Setup of domain dhcp took 0.0 seconds
2023-12-03 20:35:30.473 INFO (SyncWorker_1) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa
2023-12-03 20:35:30.473 INFO (SyncWorker_3) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant
2023-12-03 20:35:30.478 INFO (SyncWorker_0) [homeassistant.loader] Loaded camera from homeassistant.components.camera
2023-12-03 20:35:30.559 INFO (MainThread) [homeassistant.setup] Setting up bluetooth
2023-12-03 20:35:30.681 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2023-12-03 20:35:30.690 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.0 seconds
2023-12-03 20:35:30.696 INFO (SyncWorker_2) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2023-12-03 20:35:30.698 INFO (MainThread) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
2023-12-03 20:35:31.240 INFO (MainThread) [homeassistant.setup] Setting up cloud
2023-12-03 20:35:31.301 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2023-12-03 20:35:31.315 INFO (MainThread) [homeassistant.setup] Setup of domain bluetooth took 0.8 seconds
2023-12-03 20:35:31.319 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.1 seconds
2023-12-03 20:35:31.322 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds
2023-12-03 20:35:31.323 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'default_config', 'my', 'auth', 'scene', 'person', 'sensor', 'onboarding', 'homeassistant_alerts', 'stt', 'history', 'counter', 'schedule', 'input_button', 'application_credentials', 'trace', 'image_upload', 'wake_word', 'assist_pipeline', 'dlna_dms', 'hardware', 'diagnostics', 'search', 'rainbird', 'forecast_solar', 'script', 'uptime', 'met', 'mobile_app', 'file_upload', 'sun', 'radiotherm', 'lifx', 'map', 'zone', 'input_text', 'blueprint', 'device_automation', 'analytics', 'input_boolean', 'repairs', 'automation', 'smart_meter_texas', 'timer', 'input_select', 'speedtestdotnet', 'energy', 'logbook', 'conversation', 'system_health', 'lovelace', 'stream', 'tts', 'tag', 'input_datetime', 'config', 'input_number', 'media_source', 'econet'}
2023-12-03 20:35:31.327 INFO (MainThread) [homeassistant.setup] Setting up scene
2023-12-03 20:35:31.342 INFO (MainThread) [homeassistant.setup] Setting up homeassistant_alerts
2023-12-03 20:35:31.342 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant_alerts took 0.0 seconds
2023-12-03 20:35:31.342 INFO (MainThread) [homeassistant.setup] Setting up stt
2023-12-03 20:35:31.343 INFO (MainThread) [homeassistant.setup] Setup of domain stt took 0.0 seconds
2023-12-03 20:35:31.375 INFO (MainThread) [homeassistant.setup] Setting up history
2023-12-03 20:35:31.375 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds
2023-12-03 20:35:31.378 INFO (MainThread) [homeassistant.setup] Setting up counter
2023-12-03 20:35:31.486 INFO (MainThread) [homeassistant.setup] Setting up schedule
2023-12-03 20:35:31.487 INFO (MainThread) [homeassistant.setup] Setting up input_button
2023-12-03 20:35:31.487 INFO (MainThread) [homeassistant.setup] Setting up trace
2023-12-03 20:35:31.488 INFO (MainThread) [homeassistant.setup] Setup of domain trace took 0.0 seconds
2023-12-03 20:35:31.488 INFO (MainThread) [homeassistant.setup] Setting up wake_word
2023-12-03 20:35:31.489 INFO (MainThread) [homeassistant.setup] Setup of domain wake_word took 0.0 seconds
2023-12-03 20:35:31.506 INFO (MainThread) [homeassistant.setup] Setting up hardware
2023-12-03 20:35:31.512 INFO (MainThread) [homeassistant.setup] Setting up uptime
2023-12-03 20:35:31.512 INFO (MainThread) [homeassistant.setup] Setup of domain uptime took 0.0 seconds
2023-12-03 20:35:31.513 INFO (MainThread) [homeassistant.setup] Setting up sun
2023-12-03 20:35:31.513 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds
2023-12-03 20:35:31.514 INFO (MainThread) [homeassistant.setup] Setting up zone
2023-12-03 20:35:31.520 INFO (MainThread) [homeassistant.setup] Setting up input_text
2023-12-03 20:35:31.521 INFO (MainThread) [homeassistant.setup] Setting up blueprint
2023-12-03 20:35:31.521 INFO (MainThread) [homeassistant.setup] Setup of domain blueprint took 0.0 seconds
2023-12-03 20:35:31.524 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2023-12-03 20:35:31.525 INFO (MainThread) [homeassistant.setup] Setting up timer
2023-12-03 20:35:31.530 INFO (MainThread) [homeassistant.setup] Setting up input_select
2023-12-03 20:35:31.531 INFO (MainThread) [homeassistant.setup] Setting up conversation
2023-12-03 20:35:31.532 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds
2023-12-03 20:35:31.535 INFO (SyncWorker_2) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2023-12-03 20:35:31.550 INFO (MainThread) [homeassistant.setup] Setting up tag
2023-12-03 20:35:31.551 INFO (MainThread) [homeassistant.setup] Setting up input_datetime
2023-12-03 20:35:31.552 INFO (MainThread) [homeassistant.setup] Setting up input_number
2023-12-03 20:35:31.751 ERROR (MainThread) [homeassistant.setup] The rainbird integration does not support YAML setup, please remove it from your configuration
2023-12-03 20:35:31.751 INFO (MainThread) [homeassistant.setup] Setting up rainbird
2023-12-03 20:35:31.752 INFO (MainThread) [homeassistant.setup] Setup of domain rainbird took 0.0 seconds
2023-12-03 20:35:31.754 INFO (MainThread) [homeassistant.setup] Setup of domain hardware took 0.2 seconds
2023-12-03 20:35:31.774 INFO (MainThread) [homeassistant.setup] Setting up my
2023-12-03 20:35:31.775 INFO (MainThread) [homeassistant.setup] Setup of domain my took 0.0 seconds
2023-12-03 20:35:31.776 INFO (SyncWorker_3) [homeassistant.loader] Loaded ted5000 from homeassistant.components.ted5000
2023-12-03 20:35:31.792 INFO (MainThread) [homeassistant.setup] Setting up application_credentials
2023-12-03 20:35:31.806 INFO (MainThread) [homeassistant.setup] Setting up map
2023-12-03 20:35:31.807 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds
2023-12-03 20:35:31.808 INFO (MainThread) [homeassistant.setup] Setting up automation
2023-12-03 20:35:31.810 INFO (MainThread) [homeassistant.setup] Setting up energy
2023-12-03 20:35:31.810 INFO (MainThread) [homeassistant.setup] Setup of domain energy took 0.0 seconds
2023-12-03 20:35:31.820 INFO (MainThread) [homeassistant.setup] Setting up logbook
2023-12-03 20:35:31.822 INFO (MainThread) [homeassistant.setup] Setting up system_health
2023-12-03 20:35:31.824 INFO (MainThread) [homeassistant.setup] Setting up media_source
2023-12-03 20:35:31.831 INFO (MainThread) [homeassistant.setup] Setting up script
2023-12-03 20:35:31.865 INFO (MainThread) [homeassistant.setup] Setup of domain counter took 0.5 seconds
2023-12-03 20:35:31.866 INFO (MainThread) [homeassistant.setup] Setup of domain schedule took 0.4 seconds
2023-12-03 20:35:31.868 INFO (MainThread) [homeassistant.setup] Setup of domain input_button took 0.4 seconds
2023-12-03 20:35:31.872 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.1 seconds
2023-12-03 20:35:31.877 INFO (MainThread) [homeassistant.setup] Setting up forecast_solar
2023-12-03 20:35:31.877 INFO (MainThread) [homeassistant.setup] Setup of domain forecast_solar took 0.0 seconds
2023-12-03 20:35:31.885 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.1 seconds
2023-12-03 20:35:31.885 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.1 seconds
2023-12-03 20:35:31.886 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.1 seconds
2023-12-03 20:35:31.886 INFO (MainThread) [homeassistant.setup] Setup of domain media_source took 0.1 seconds
2023-12-03 20:35:31.892 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.4 seconds
2023-12-03 20:35:31.895 INFO (MainThread) [homeassistant.setup] Setup of domain input_text took 0.4 seconds
2023-12-03 20:35:31.896 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 0.4 seconds
2023-12-03 20:35:31.897 INFO (MainThread) [homeassistant.setup] Setup of domain timer took 0.4 seconds
2023-12-03 20:35:31.899 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 0.4 seconds
2023-12-03 20:35:31.908 INFO (MainThread) [homeassistant.setup] Setting up met
2023-12-03 20:35:31.908 INFO (MainThread) [homeassistant.setup] Setup of domain met took 0.0 seconds
2023-12-03 20:35:31.947 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2023-12-03 20:35:31.949 INFO (MainThread) [homeassistant.setup] Setup of domain application_credentials took 0.2 seconds
2023-12-03 20:35:31.950 INFO (MainThread) [homeassistant.setup] Setup of domain input_datetime took 0.4 seconds
2023-12-03 20:35:31.951 INFO (MainThread) [homeassistant.setup] Setup of domain input_number took 0.4 seconds
2023-12-03 20:35:31.952 INFO (MainThread) [homeassistant.setup] Setup of domain tag took 0.4 seconds
2023-12-03 20:35:31.954 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.6 seconds
2023-12-03 20:35:31.980 INFO (MainThread) [homeassistant.setup] Setting up dlna_dms
2023-12-03 20:35:31.980 INFO (MainThread) [homeassistant.setup] Setup of domain dlna_dms took 0.0 seconds
2023-12-03 20:35:31.986 INFO (MainThread) [homeassistant.setup] Setting up radiotherm
2023-12-03 20:35:31.986 INFO (MainThread) [homeassistant.setup] Setup of domain radiotherm took 0.0 seconds
2023-12-03 20:35:32.043 INFO (MainThread) [homeassistant.setup] Setting up lifx
2023-12-03 20:35:32.043 INFO (MainThread) [homeassistant.setup] Setup of domain lifx took 0.0 seconds
2023-12-03 20:35:32.060 INFO (MainThread) [homeassistant.setup] Setting up smart_meter_texas
2023-12-03 20:35:32.060 INFO (MainThread) [homeassistant.setup] Setup of domain smart_meter_texas took 0.0 seconds
2023-12-03 20:35:32.069 INFO (MainThread) [homeassistant.setup] Setting up speedtestdotnet
2023-12-03 20:35:32.069 INFO (MainThread) [homeassistant.setup] Setup of domain speedtestdotnet took 0.0 seconds
2023-12-03 20:35:32.079 INFO (MainThread) [homeassistant.setup] Setting up stream
2023-12-03 20:35:32.151 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.1 seconds
2023-12-03 20:35:32.600 INFO (MainThread) [homeassistant.setup] Setting up econet
2023-12-03 20:35:32.601 INFO (MainThread) [homeassistant.setup] Setup of domain econet took 0.0 seconds
2023-12-03 20:35:32.650 INFO (MainThread) [homeassistant.setup] Setting up tts
2023-12-03 20:35:32.658 INFO (MainThread) [homeassistant.setup] Setting up sensor
2023-12-03 20:35:32.658 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds
2023-12-03 20:35:32.669 INFO (SyncWorker_4) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2023-12-03 20:35:32.671 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.0 seconds
2023-12-03 20:35:32.672 INFO (SyncWorker_3) [homeassistant.loader] Loaded button from homeassistant.components.button
2023-12-03 20:35:32.673 INFO (SyncWorker_4) [homeassistant.loader] Loaded select from homeassistant.components.select
2023-12-03 20:35:32.673 INFO (SyncWorker_0) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
2023-12-03 20:35:32.673 INFO (SyncWorker_3) [homeassistant.loader] Loaded light from homeassistant.components.light
2023-12-03 20:35:32.678 INFO (MainThread) [homeassistant.setup] Setting up button
2023-12-03 20:35:32.679 INFO (MainThread) [homeassistant.setup] Setup of domain button took 0.0 seconds
2023-12-03 20:35:32.680 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2023-12-03 20:35:32.680 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.0 seconds
2023-12-03 20:35:32.681 INFO (MainThread) [homeassistant.setup] Setting up light
2023-12-03 20:35:32.682 INFO (MainThread) [homeassistant.setup] Setting up select
2023-12-03 20:35:32.683 INFO (MainThread) [homeassistant.setup] Setup of domain select took 0.0 seconds
2023-12-03 20:35:32.755 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2023-12-03 20:35:32.756 INFO (MainThread) [homeassistant.setup] Setting up assist_pipeline
2023-12-03 20:35:32.761 INFO (MainThread) [homeassistant.setup] Setup of domain light took 0.1 seconds
2023-12-03 20:35:32.800 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.0 seconds
2023-12-03 20:35:32.805 INFO (MainThread) [homeassistant.setup] Setup of domain assist_pipeline took 0.0 seconds
2023-12-03 20:35:32.807 INFO (MainThread) [homeassistant.setup] Setting up notify
2023-12-03 20:35:32.807 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds
2023-12-03 20:35:32.813 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
2023-12-03 20:35:32.817 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2023-12-03 20:35:32.819 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 0.0 seconds
2023-12-03 20:35:32.819 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.ted5000
2023-12-03 20:35:32.826 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.uptime
2023-12-03 20:35:32.827 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.sun
2023-12-03 20:35:32.831 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.energy
2023-12-03 20:35:32.836 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.lifx
2023-12-03 20:35:32.837 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.lifx
2023-12-03 20:35:32.841 INFO (MainThread) [homeassistant.components.button] Setting up button.lifx
2023-12-03 20:35:32.842 INFO (MainThread) [homeassistant.components.button] Setting up button.lifx
2023-12-03 20:35:32.843 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.lifx
2023-12-03 20:35:32.846 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.lifx
2023-12-03 20:35:32.847 INFO (MainThread) [homeassistant.components.select] Setting up select.lifx
2023-12-03 20:35:32.848 INFO (MainThread) [homeassistant.components.select] Setting up select.lifx
2023-12-03 20:35:32.850 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.speedtestdotnet
2023-12-03 20:35:32.850 INFO (MainThread) [homeassistant.components.light] Setting up light.lifx
2023-12-03 20:35:32.851 INFO (MainThread) [homeassistant.components.light] Setting up light.lifx
2023-12-03 20:35:32.859 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mobile_app
2023-12-03 20:35:32.859 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.mobile_app
2023-12-03 20:35:32.860 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mobile_app
2023-12-03 20:35:32.860 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.mobile_app
2023-12-03 20:35:32.861 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.mobile_app
2023-12-03 20:35:32.862 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.mobile_app
2023-12-03 20:35:32.883 INFO (MainThread) [homeassistant.setup] Setting up default_config
2023-12-03 20:35:32.886 INFO (SyncWorker_4) [homeassistant.loader] Loaded backup from homeassistant.components.backup
2023-12-03 20:35:32.908 INFO (MainThread) [homeassistant.setup] Setting up backup
2023-12-03 20:35:32.908 INFO (MainThread) [homeassistant.setup] Setup of domain backup took 0.0 seconds
2023-12-03 20:35:32.909 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.0 seconds
2023-12-03 20:35:33.143 INFO (SyncWorker_4) [homeassistant.loader] Loaded weather from homeassistant.components.weather
2023-12-03 20:35:33.147 INFO (MainThread) [homeassistant.setup] Setting up weather
2023-12-03 20:35:33.148 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 0.0 seconds
2023-12-03 20:35:33.152 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.forecast_solar
2023-12-03 20:35:33.159 INFO (MainThread) [homeassistant.components.weather] Setting up weather.met
2023-12-03 20:35:33.649 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.smart_meter_texas
2023-12-03 20:35:35.136 INFO (SyncWorker_4) [homeassistant.loader] Loaded number from homeassistant.components.number
2023-12-03 20:35:35.137 INFO (SyncWorker_4) [homeassistant.loader] Loaded calendar from homeassistant.components.calendar
2023-12-03 20:35:35.138 INFO (SyncWorker_5) [homeassistant.loader] Loaded switch from homeassistant.components.switch
2023-12-03 20:35:35.139 INFO (MainThread) [homeassistant.setup] Setting up number
2023-12-03 20:35:35.140 INFO (MainThread) [homeassistant.setup] Setup of domain number took 0.0 seconds
2023-12-03 20:35:35.141 INFO (SyncWorker_0) [homeassistant.loader] Loaded switch_as_x from homeassistant.components.switch_as_x
2023-12-03 20:35:35.142 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rainbird
2023-12-03 20:35:35.148 INFO (MainThread) [homeassistant.setup] Setting up calendar
2023-12-03 20:35:35.148 INFO (MainThread) [homeassistant.setup] Setup of domain calendar took 0.0 seconds
2023-12-03 20:35:35.151 INFO (MainThread) [homeassistant.setup] Setting up switch
2023-12-03 20:35:35.151 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds
2023-12-03 20:35:35.156 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.rainbird
2023-12-03 20:35:35.158 INFO (MainThread) [homeassistant.components.number] Setting up number.rainbird
2023-12-03 20:35:35.158 INFO (MainThread) [homeassistant.components.calendar] Setting up calendar.rainbird
2023-12-03 20:35:35.158 INFO (MainThread) [homeassistant.components.switch] Setting up switch.rainbird
2023-12-03 20:35:35.766 INFO (SyncWorker_5) [homeassistant.loader] Loaded climate from homeassistant.components.climate
2023-12-03 20:35:35.768 INFO (MainThread) [homeassistant.setup] Setting up climate
2023-12-03 20:35:35.770 INFO (MainThread) [homeassistant.setup] Setup of domain climate took 0.0 seconds
2023-12-03 20:35:35.771 INFO (MainThread) [homeassistant.components.switch] Setting up switch.radiotherm
2023-12-03 20:35:35.774 INFO (MainThread) [homeassistant.components.climate] Setting up climate.radiotherm
2023-12-03 20:35:36.106 INFO (SyncWorker_3) [homeassistant.loader] Loaded water_heater from homeassistant.components.water_heater
2023-12-03 20:35:36.110 INFO (MainThread) [homeassistant.setup] Setting up water_heater
2023-12-03 20:35:36.111 INFO (MainThread) [homeassistant.setup] Setup of domain water_heater took 0.0 seconds
2023-12-03 20:35:36.111 INFO (MainThread) [homeassistant.components.climate] Setting up climate.econet
2023-12-03 20:35:36.114 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.econet
2023-12-03 20:35:36.114 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.econet
2023-12-03 20:35:36.115 INFO (MainThread) [homeassistant.components.water_heater] Setting up water_heater.econet
2023-12-03 20:35:52.645 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 23.38s
2023-12-03 20:35:52.646 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2023-12-03 20:35:52.690 INFO (SyncWorker_0) [homeassistant.loader] Loaded homekit_controller from homeassistant.components.homekit_controller
2023-12-03 20:35:52.712 INFO (SyncWorker_1) [homeassistant.loader] Loaded bluetooth_adapters from homeassistant.components.bluetooth_adapters
2023-12-03 20:35:52.736 INFO (SyncWorker_1) [homeassistant.loader] Loaded shelly from homeassistant.components.shelly
2023-12-03 20:35:52.736 INFO (SyncWorker_1) [homeassistant.loader] Loaded ruuvi_gateway from homeassistant.components.ruuvi_gateway
2023-12-03 20:35:52.740 INFO (SyncWorker_4) [homeassistant.loader] Loaded esphome from homeassistant.components.esphome
2023-12-03 20:35:52.875 INFO (MainThread) [homeassistant.setup] Setting up bluetooth_adapters
2023-12-03 20:35:52.875 INFO (MainThread) [homeassistant.setup] Setup of domain bluetooth_adapters took 0.0 seconds
2023-12-03 20:35:52.901 INFO (SyncWorker_0) [homeassistant.loader] Loaded thread from homeassistant.components.thread
2023-12-03 20:35:53.205 ERROR (MainThread) [homeassistant.components.speedtestdotnet.coordinator] Error fetching speedtestdotnet data: Selected server is not found.
While more verbose, it does not seem terribly helpful. Is there a more detailed log setting?
My config.yaml is
# Loads default set of integrations. Do not remove.
default_config:
# More logging per https://community.home-assistant.io/t/ha-stopped-working-after-a-year-where-do-i-start-looking/648417/15
logger:
default: info
# Text to speech
tts:
- platform: google_translate
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
- platform: ted5000
host: 192.168.0.195
rainbird:
host: 192.168.0.194
password: XXXXXXXXXX
trigger_time: 360
automations, scripts, and scenes are all whatever the default was (blank - althogh automations has a a set of empty square brackets in it)
