My HA is entering stop mode very unexpectedly.
Under normal conditions the service is in standby mode.
I have already changed several settings and nothing to solve the problem. As it is running on the raspberry pi I have already changed the same and nothing.
The raspberry pi does not restart or shut down only the service that is stopped.
First of all, I think you need to indicate which installation method you are using (hassio, hassbian, docker, aio etc) and put the thread in the appropriate category. Then you may get some help from people with experience with that installation.
To be honest, I don’t know because I have never had to do it. But other people have managed when I suggested it, so it must be possible.
Then I may be able to help. The reason I asked was that I didn’t recognize this sentence
A normal active service should be active (running) like
pi@hassbian:~
$ systemctl status [email protected]
● [email protected] - Home Assistant for homeassistant
Loaded: loaded (/etc/systemd/system/[email protected]; ena
Active: active (running) since Thu 2018-06-21 09:47:42 BST; 2 weeks 0 days ag
Main PID: 23602 (hass)
CGroup: /system.slice/system-home\x2dassistant.slice/home-assistant@homeassis
└─23602 /srv/homeassistant/bin/python3 /srv/homeassistant/bin/hass
